Converting relative browse paths to node ids and validating them
the stringParsingError comes out null in that example. That is what the example is meant to show.
Which QuickOPC version are you using? I will install it on a new machine and test the example out of the box.
Are you sure stringParsingError is null? for me it is populated with the error mentioned below.
I do not not understand your post.
The example works for me without error. Are you saying that it does not work for you?
Or, if you are using a different code, post the code here.
Example: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User's...0relative%20browse%20path.html
I do not know what you mean by NamespaceId, no such term is used in OPC UA.
The proper way way is to specify namespaces in OPC UA is using their namespace URIs. Unfortunately, the Web is full of examples that use namespace indexes, which (except for namespaces 0 and 1) is server free to shuffle between sessions, so all these examples are technically wrong. Also, the "standard" OPC UA browse path syntax uses namespace indexes, so it is not usable without having a context - which index corresponds to which URI.
In the code I provided, there are three example with equivalent effect. The first one, and the subsequent (commented out) one use namespace URIs.
The last one uses namespace indexes. It is close to what you have asked for in your original post, and you are free to use it, but be that "namespace with index 2" is not a stable thing. The first two examples do not have this problem.
In QuickOPC, nodes can be specified either by their node ID, or by an absolute browse path (a combination of a starting node, and a relative browse path). The conversion from the browse path to the node Id happens automatically inside QuickOPC, you do not call anything extra.
Example:
// This example shows how to read the node using a browse path.
// Find all latest examples here: opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Latest/examples.html .
// OPC client and subscriber examples in C# on GitHub: github.com/OPCLabs/Examples-QuickOPC-CSharp .
// Missing some example? Ask us for it on our Online Forums, www.opclabs.com/forum/index ! You do not have to own
// a commercial license in order to use Online Forums, and we reply to every post.
using System;
using OpcLabs.EasyOpc.UA;
using OpcLabs.EasyOpc.UA.Navigation;
namespace UADocExamples._EasyUAClient
partial class Read
public static void BrowsePath()
UAEndpointDescriptor endpointDescriptor =
"opc.tcp://opcua.demo-this.com:51210/UA/SampleServer";
// or " opcua.demo-this.com:51211/UA/SampleServer " (currently not supported)
// or " opcua.demo-this.com:51212/UA/SampleServer/ "
// Create the node descriptor by parsing an absolute browse path.
// The syntax below specifies a common default namespace URI for the elements of the browse path.
UANodeDescriptor nodeDescriptor = UABrowsePath.Parse("[ObjectsFolder]/Data/Dynamic/Scalar/FloatValue", " test.org/UA/Data/ ");
// Alternatively, the namespace URIs can be specified with each element of the browse separately.
//UANodeDescriptor nodeDescriptor = UABrowsePath.Parse("[ObjectsFolder]/[nsu=http://test.org/UA/Data/;Data]/[nsu=http://test.org/UA/Data/;Dynamic]/[nsu=http://test.org/UA/Data/;Scalar]/[nsu=http://test.org/UA/Data/;FloatValue]", null);
// Alternatively, the namespaces can be specified by indexes, separately with each element.
//UANodeDescriptor nodeDescriptor = UABrowsePath.Parse("[ObjectsFolder]/2:Data/2:Dynamic/2:Scalar/2:FloatValue", null);
// Obtain attribute data. By default, the Value attribute of a node will be read.
UAAttributeData attributeData;
try
attributeData = client.Read(endpointDescriptor, nodeDescriptor);
catch (UAException uaException)
Console.WriteLine($"*** Failure: {uaException.GetBaseException().Message}");
return;
// Display results
Console.WriteLine($"Value: {attributeData.Value}");
Console.WriteLine($"ServerTimestamp: {attributeData.ServerTimestamp}");
Console.WriteLine($"SourceTimestamp: {attributeData.SourceTimestamp}");
Console.WriteLine($"StatusCode: {attributeData.StatusCode}");
I hope this helps
I am looking for a c# code snipit to do such a thing.
