Can't write to KepServer V5 word tag with uint16 type
15 May 2018 15:58 #6336 by support
Do not worry, this is OK.
In addition, I think that what you describe is for the situation when there was no error reported.
When there was "BadTypeMismatch", my suggestion could still apply. So let's keep it here.
15 May 2018 15:53 #6335 by Taid
Thanks for quick reply.
After further looking into logic on the PLC itself it seems that this datablock is heavily controlled by some higher logic and those few tags do not persist the data I write onto them since the functions overrides them every time.
Feel free to delete this topic as it had nothing to do with your software.
Sorry for taking your time :(.
Piotr
15 May 2018 10:07 #6333 by support
Please have a look at this:
opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...e%20in%20OPC%20UA%20Write.html
And specify the type explicitly, similar to the example provided.
Let me know if it helped.
15 May 2018 06:50 #6331 by Taid
I'm creating a small asp.net page to help control data flow between MySQL and S7-300 PLC on one of our machines and I run into a weird road block in writing to a tag which on server is declared as WORD and it's type should be a simple integer on the PLC. As a side note, I'm still using the trial version (version 5.52.91.1) and this is the last point before we make a purchase of your OPC client.
I did try using EasyOPCUADemo and connectivity explorer but the result seems the same. I get no error when the value type declared is UINT16 but no value is written on the PLC. If I go with any other type I do get the BadTypeMismatch error.
Response of connectivity explorer when no value type is specified:
https://imgur.com/ZV4DawM
Response of connectivity explorer when uint16 value type is specified:
https://imgur.com/Q9xQz3C
Testing with WriteValue and WriteMultiple yields the same results (no error no value on PLC).
Best regards, Piotr
