Subscribed tag failed to Trigger
We've found the problem.
We're using Wonderware Intouch to change the tags on a Timer using an "On True" condition. Apparently there is a know issue you with the "On True" condition. We've switch to using "While True" and this has solved the problem.
Again Thanks for your help.
Damian
thanks for the code.
I do not see any real problem with it. The handler logic should ideally be somewhat different, but that's not serious. Normally you would test for the .Exception first: If that is non-null, then Vtq *is* null, and the .Exception (and other properties) gives more info about the problem. If .Exception is null, then Vtq is always non-null, and contains what the server has sent. More details: E.g. the Concepts document, section Best Practices ("Always test the Exception property before accessing the actual result (Value, Vtq, or AttributeData property)".
I assume you do not see any errors (in the .Exception; or, in your logic, null-Vtq-s or bad Qualities) during those 72 hours? If so, we should start looking into the details of these errors first.
If there are no errors, and you still think you are missing some updates, what is the evidence for that claim? Do you have some server log, or info from other OPC client?
If everything else fails, a special tool (OPC Analyzer) can be used to log the traffic between the client and the server.
And (hopefully unrelated to the problem you reported): Please do *not* use the Handle to identify the subscribed item in the callback handler. For explanation, see the Concepts document, section Best Practices: "Use the state instead of handles to identify subscribed entities".
>Do you also access the subscribed tag in some other way? E.g. by reading it from time, either using QuickOPC, or some other OPC client?
No this is the only method we are accessing the tag.
The code is divided in 2 layers...
OpcClient Layer
Application Layer
The reason I am asking is because we have seen servers "confusing" the different accesses (that should be independent), and then forgetting to send the right update.
Also, can you please post the piece of code (or basic structure of it) that handles the data change notification? Reason: I want to check whether the various situations that can emerge (esp. the error checking) are done right.
We are using QuickOPC v5.23 with Wonderware FS Gateway 2.0.1 and Wonderware InTouch 10.5.001.
Our application is subscribed to 1 tag.
Intouch changes this tag every minute.
Over the course of 72 hours in testing it appears from our logs that our application missed the tag change on 79 occasions.
What is the best way to attempt to diagnose the problem?
Damian
