C# example for reading multiple OPC UA tags
12 Feb 2016 12:44 #3847 by support
For a list of available examples: Start -> OPC Labs -> QuickOPC 5.3 -> Examples (.NET Source Code) -> About Examples,
or www.opclabs.com/files/documents/QuickOpc/Latest/Examples-QuickOPC.pdf .
A VS solution with C# examples: Start -> OPC Labs -> QuickOPC 5.3 -> Examples (.NET Source Code) -> Visual C# Examples.
In that solution, reading of multiple OPC UA tags can be seen in following examples:
  • Console -> UADocExamples -> _EasyUAClient.ReadMultiple.Main
  • Console -> UADocExamples -> _EasyUAClient.ReadMultipleValues.Main
And here is an actual code snippet taken from one of the examples:
public static void Main() { // Instantiate the client object var easyUAClient = new EasyUAClient(); // Obtain attribute data. By default, the Value attributes of the nodes will be read. UAAttributeDataResult[] attributeDataResultArray = easyUAClient.ReadMultiple(new[] { new UAReadArguments("http://opcua.demo-this.com:51211/UA/SampleServer", "nsu=http://test.org/UA/Data/;i=10845"), new UAReadArguments("http://opcua.demo-this.com:51211/UA/SampleServer", "nsu=http://test.org/UA/Data/;i=10853"), new UAReadArguments("http://opcua.demo-this.com:51211/UA/SampleServer", "nsu=http://test.org/UA/Data/;i=10855") }); // Display results foreach (UAAttributeDataResult attributeDataResult in attributeDataResultArray) Console.WriteLine("AttributeData: {0}", attributeDataResult.AttributeData); // Example output: // //AttributeData: 51 {System.Int16} @11/6/2011 1:49:19 PM @11/6/2011 1:49:19 PM; Good //AttributeData: -1993984 {System.Single} @11/6/2011 1:49:19 PM @11/6/2011 1:49:19 PM; Good //AttributeData: Yellow% Dragon Cat) White Blue Dog# Green Banana- {System.String} @11/6/2011 1:49:19 PM @11/6/2011 1:49:19 PM; Good }
I hope this helps
Zbynek Zahradnik
12 Feb 2016 12:33 #3846 by support
Sent: Friday, February 12, 2016 11:12 AM
To: Z.
Subject: RE: OPC Labs Contact Form - Trial license
Hello Zbynek,
[...] “QuickOPC Standard, [...]. We will use this for an C# OPC UA client reading multiple tags, but I can’t find a C# program example?
Med venlig hilsen/Best regards
