- Thank you received: 1
The OPC-UA subscription publishing has stopped.
- Alex-Derksen
Topic Author
- Offline
- Elite Member
Yours Sincerely,
Alex
- Alex-Derksen
Topic Author
- Offline
- Elite Member
In this I attached the file "HMI-Tace.log".
Yours Sincerely,
Alex
- Alex-Derksen
Topic Author
- Offline
- Elite Member
In our application, we have already made an implementation about trace, error and EasyUAClient.LogEntry logging. In the file HMI-Tace.log (txt file), you can see the tracing of the tags that are subscribed and the EasyUAClient event log items. The logging is sequential and for very log line, a stamp time writes. In another file “properties.xlsx” you can see the properties of the parameters per group and group-item.
I hope you can give a response of this logging information, if you want to have more logging or tips to get more data information about the “BadSubscriptionIdInvalid” or “The OPC-UA subscription publishing has stopped” let me know.
Yours Sincerely,
Alex
Attachment 2 files.
OK, in this situation I suggest that we obtain more information about the communication. This can be done on various levels - with more and more effort. I suggest to start gradually: Can you please add an event handler for the static event EasyUAClient.LogEntry, and store all information (mainly, the time and the message, but the more the better) into a text file or similar? And, if the server has some kind of diagnostics, capture that as well. Then send the diagnostics back to us. This should at least tell us what the final timing parameters in use are, and how significantly are they getting exceeded. From that we should see whether it is meaningful to try "tuning" the parameters and how, or whether there is a deeper problem that the parameter changes cannot resolve.
- Alex-Derksen
Topic Author
- Offline
- Elite Member
In you answer on 17 July 16:08: That OPC Labs cannot 100% guarantees the communication about the OS, but by setting the various parameters cleverly and the network are not overloaded, one can get the probability to almost zero. Can you give our more suggestion about setting the various parameters?
Again sorry for my incorrect answer, but can you help us even further to get a better end-result. In the afternoon I have a meeting with Bosch Rexroth about these problems.
Yours Sincerely,
Alex
I should note that in general, this problem *cannot* be avoided with 100% guarantee. Because OPC UA is not a real-time protocol, and Windows is not a real-time OS, there is no upper bound on how long things can take - and this error is an indication of a keep-live mechanism kicking in, detecting the situation and attempting to resolve it. Obviously by setting the various parameters cleverly (which is what the updated version does better), and making sure that the computer and the network are not overloaded, one can get the probability to almost zero.
- Alex-Derksen
Topic Author
- Offline
- Elite Member
Please let us know your feedback in any case and if I am not clear in my questions, let me know.
- Alex-Derksen
Topic Author
- Offline
- Elite Member
In the attachments is more informations about or problems.
If you have any questions or remarks, please let me know.
