- Thank you received: 5
Browse Citect Plant SCADA doesn't show the items under the BrowseProvider folder
It appears that there must be some configurations in Plant SCADA side to enable the OPC UA server to properly work. It is not the client's problem.
Thank you for your support.
I understand. I will send you the server's URL privately via email. You will have to coordinate this with me since the computer is not always on.
By "connecting to your computer", I did not mean exposing it for remote desktop connection or something alike. I meant if you could expose the endpoint of the OPC UA server, so that I can connect through OPC UA to it. This is usually done by opening that specific port on a firewall (and it can be limited to access from a specific IP, which I can email to you).Can you do it?
Thank you for your answer. As I mentioned below we are using version 5.80.278 and LoosereferenceTypes is set to True.
If you need Plant SCADA you may download it from here:
drive.google.com/drive/folders/1fckYDwY9fHlY80u7JXLSFWoZTEpd2lLZ
You can just install Plant SCADA and Update 15 (the latest update). When you install Plant SCADA you must check "OPC UA Server" during the installation.
You can connect to my computer as well.
These are the same problematic HasChild abstract references that have triggered the original issue. It would be expected that they QuickOPC shows nothing with versions before 5.80.191, or with 5.80.191+ but when LoosereferenceTypes is set to False.
If you are sure that you are running 5.80.191 or later and have LoosereferenceTypes set to True, then we need to investigate further. But I will need a copy of the server to run here, or you will need to expose the server endpoint to me for remote connection.
Thank you for your answer. Now I have Plant SCADA installed on my computer and I can see then problem on my computer.
See the screen captures below.
Using QuickOPC browsing:
Using UA Expert Browsing:
You can see that under the item "RoomA" there are 0 leaves" when using Quick OPC browser.
In UA Explorer you can see all the items and folders under "RoomA": Light1, Level and all the items.
I appreciate your help.
So apparently you have reason to think that there should be sub-nodes displayed under "11kV_1_2".
Can you please send a screenshot from uaExpert where this node is selected and its sub-nodes displayed, similarly as you did before with the original issue?
