Cannot access certificate private key
08 Oct 2024 11:42 #13210 by AlexSFromG
Hello Support,
thank you for your kind response.
I finally could solve the situation by making a copy of the folder x:\ProgramData\OPC Foundation\CertificateStores\MachineDefault\private
from a machine that works properly to the machine which refuses to work.
I don't know why on this machine the certificates had not created.
Perhaps do you know the answer and can leave ist for people who are looking for a silimlar solution.
Thank You
Alex
08 Oct 2024 07:35 #13209 by support
Have you checked the certificate stores whether the private key is actually there (if you do not know how, I can provide guidance)?
If you are using self-signed certificate, it might be wort trying to delete the existing certificate and then let the program re-generate it (again, I can help with it if you need).
08 Oct 2024 05:19 #13207 by AlexSFromG
Hello everybody,
I never had difficulties to set up QuickOPC for UA on my terminals.
But one Terminal refuses to work with the following errors:
OPC-UA operation failure wirt herror code -213850216 (0x80890000) occurred, originated from opc.ua.configuration. The inner OPC-UA service exceptione with service result "BadConfigurationError" contains details about the problem. OpcLabs.EasyOPC.UA.UAServiceException; OPC-UA service result - Cannot access certificate private key: Subject=CN= ....
Are there any known solutions to this message?
Alex
