Exception when browsing an OPC UA Server
I would need a reproducible scenario to look further into this.
Are you sure that with the 2nd option, you have changed the name of the property (on the left to '=') as well?
1) Do it in your code - something like below - this gives you absolute power because you can write any code to construct the application URI:
2) Use the "template" syntax for the application URI, with pre-defined replaceable symbols ( kb.opclabs.com/OPC_UA_Application_URI_Derivation ). QuickOPC will then fill in the computer name for you, in place of the "$(HostName)". In this case the property that you set is different - and it would look similar to this:
Thank you. How can I add the computer name programmatically?
Do I need to check the computer name and add it myself?
You are good with your choice, if you know there won't be any other computer using precisely the same application URI. If there is such a risk, you should put some more distinguishing info into the application URI - and that can be the computer name, if you like.
I tried this:
EasyUAFormsApplication.Instance.ApplicationParameters.ApplicationManifest.ApplicationUriString = "uri:EBO-OPCClientCFG" ' Nov-13-2023
EasyUAFormsApplication.Instance.AddToSystemMenu(Me)
Is this syntax correct? No need for the computer name in the URI?
Thank you. We shall try it.
No, this is not about application name.
What matters here is the application URI. There is no ready-to-use example for it in the documentation, but the article explains the concepts. Your code needs to simply set EasyUAApplication.Instance.ApplicationParameters.ApplicationManifest.ApplicationUriString to a URI that is unique in the overall target OPC UA system.
When you set it as above, and then re-create the certificate, it will then be displayed next to "Subject URL Name".
