Siemens OPC Server: error calling method
19 Mar 2018 14:03 #6161 by support
Great :-)
Thanks for letting me know and explaining the problem, and its solution here.
19 Mar 2018 13:27 #6159 by federica
Thank you for your quick reply!
I solved my problem.
The message I received was:
Description
"OPC-UA service result - An error specific to OPC-UA service occurred.
---- SERVICE RESULT ----
StatusCode: {BadUserAccessDenied} = 0x801F0000 (2149515264)
---- REMARKS ----
This error should mean an authorization (permissions) problem, not an authentication problem, but some servers are using it instead of rejecting the identity token (BadIdentityTokenRejected).
If you are identifying the client user by a user name token, it could be that the user name/password combination is incorrect."
ErrorMessage
"Unknown error 0x80131500"
With Siemens OPC Server, I have to authenticate with a user. With anonymous user, I can't call methods and I can't access to the values of the variables.
This code solved my problem:
_EasyUAClientPtr ClientPtr(__uuidof(EasyUAClient)); _EasyUAAdaptableParametersPtr IsolatedParameters = ClientPtr->GetIsolatedParameters(); _UASmartSessionParametersPtr SessionParms = IsolatedParameters->GetSessionParameters(); ClientPtr->Isolated = TRUE; SessionParms->UserIdentity->UserNameTokenInfo->UserName = L"***username***"; SessionParms->UserIdentity->UserNameTokenInfo->Password = L"***password***";
10 Mar 2018 06:16 - 10 Mar 2018 06:17 #6132 by admin
As there can be many error reasons, you need to obtain and give us more details about the error.
For start, _com_error ( msdn.microsoft.com/en-us/library/0ye3k36s.aspx ). For start, what is the error's ErrorMessage?: msdn.microsoft.com/en-us/library/7db325b0.aspx
Last edit: 10 Mar 2018 06:17 by admin.
The following user(s) said Thank You: federica
09 Mar 2018 21:26 #6131 by federica
I'm starting using your SDK (QuickOPC 2018.1, in particular OPC-UA under COM with C++) and I need your help.
I need to read some variables from a Siemens Sinumeric 840D sl.
From the Sinumerik documentation:
"All variables that cannot be accessed via browsing can only be read and written via the 'ReadVar' and 'WriteVar' methods".
So, I'm using "CallMethod" function in order to call "ReadVar" method and read my variables, following the example I found at this address: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...g%20Methods%20in%20OPC-UA.html
[...] CComSafeArray<VARIANT> inputs(1); inputs.SetAt(0, _variant_t(L"/Plc/Db1070.dbb0")); CComSafeArray<VARIANT> typeCodes(1); typeCodes.SetAt(0, _variant_t(TypeCode_String)); // Instatiate the client object _EasyUAClientPtr ClientPtr(__uuidof(EasyUAClient)); // Perform the operation SAFEARRAY* pInputs = inputs; SAFEARRAY* pTypeCodes = typeCodes;; CComSafeArray<VARIANT> outputs; ClientPtr->CallMethod( L"opc.tcp://**address**:**port**", L"ns=2;s=/Methods", L"ns=2;s=/Methods/ReadVar", &pInputs, &pTypeCodes); [...]
But when I call "CallMethod", I receive a _com_error.
I think there is a problem in the way I specify the objectNodeDescriptorString and/or the methodNodeDescriptorString and/or the input parameter but I'm not sure and I can't figure out which is the problem and how to solve it.... can anyone help me, please... I have to get my project in production for thuesday. :unsure:
Thanks!
