EasyOPC parameter information
29 Apr 2012 18:17 #832 by support
Sent: Tuesday, March 27, 2012 5:36 AM
To: P.
Subject: RE: EasyOPC Parameter Information
<span style="font-family: "Arial","sans-serif"; font-size: 12pt">Hello.
<span style="font-family: "Arial","sans-serif"; font-size: 12pt">The details are in the reference manual. The reference is, by default, installed with the product, and also integrated with Help system in Visual Studio. You should therefore be able to use Help as usually, and start from EasyDAClient object, and then follow down to its properties (such as ClientMode, HoldPeriods, Timeouts, UpdateRates) and, if needed, the properties of the contained objects, and so on.
<span style="font-family: "Arial","sans-serif"; font-size: 12pt">You can also get to the reference from the Start menu, find the QuickOPC group, then it is under Documentation and Help -> QuickOPC Reference (.NET) .
<span style="font-family: "Arial","sans-serif"; font-size: 12pt">The reference manual is also available on Web: www.opclabs.com/onlinedocs/QuickOpcClassic/5.12/Reference/QuickOpcNet/index.html
<span style="font-family: "Arial","sans-serif"; font-size: 12pt">Best regards,
<span style="font-family: "Arial","sans-serif"; font-size: 12pt">Zbynek Zahradnik, OPC Labs
<span style="font-family: "Arial","sans-serif"; font-size: 12pt">From:<span style="font-family: "Arial","sans-serif"; font-size: 12pt"> P.
Sent: Monday, March 26, 2012 9:18 PM
Subject: EasyOPC Parameter Information
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB">Zbynek<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> <span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB">Can you tell me where I will find details of the following parameters:-<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.ClientMode.AllowAsynchronousMethod = true;<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.ClientMode.AllowSynchronousMethod = true;<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.ClientMode.Caller = "";<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.ClientMode.DataSource = OpcLabs.EasyOpc.DataAccess.DADataSource.ByValueAge;<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.ClientMode.DesiredMethod = OpcLabs.EasyOpc.DataAccess.DAReadWriteMethod.Asynchronous;<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.ClientMode.DesiredValueAge = 1000;<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.ClientMode.Isolated = false;<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.HoldPeriods.ItemDetach = 5000;<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.HoldPeriods.ServerDetach = 30000;<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.HoldPeriods.TopicRead = 120000;<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.HoldPeriods.TopicWrite = 120000;<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.Timeouts.BrowseAccessPaths = 60000;<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.Timeouts.BrowseNodes = 60000;<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.Timeouts.BrowseProperties = 60000;<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.Timeouts.BrowseServers = 60000;<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.Timeouts.GetProperty = 60000;<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.Timeouts.ReadItem = 60000;<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.Timeouts.WriteItem = 60000;<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.UpdateRates.ReadAutomatic = 10000;<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB"> opcDAClient.UpdateRates.WriteAutomatic = -1;<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-ansi-language: EN-GB">Regards<span style="font-family: "Arial","sans-serif"; font-size: 12pt">
<span lang="EN-GB" style="font-family: "Arial","sans-serif"; font-size: 12pt; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-ansi-language: EN-GB; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">P.
Time to create page: 0.165 seconds
