System goes slower and slower
In order to prevent this behavior, set the UpdateRates.ReadAutomatic property of your EasyDAClient instance to System.Threading.Timeout.Infinite.
- owe@eurosys.se
Topic Author
- Offline
- New Member
- Thank you received: 0
I've trid to use/instantiate a new opcclient localy withing each method and to use
a global static instance used by all threads.
I don't know which variant you recommend?
The problem though I think is as you said with the internal subscriptions to satisfy
my Reads.
>Regards Owe
- owe@eurosys.se
Topic Author
- Offline
- New Member
The reads that you do after each "trigger", are they generally to items that you have subscribed to or used before?
The reads after trigger are to items not subscribed to. They will be read for every product entering the station, about every
20 second. We only subscribe to tags that we want to trigger us to do something.
>Regards Owe
- owe@eurosys.se
Topic Author
- Offline
- New Member
I will send you information tonight. Should I post it on this thread or?
>Regards owe
The way you have described the characteristics of your application is very good. If there is anything more that can help me understand what the application does and how, please send it as well.
- owe@eurosys.se
Topic Author
- Offline
- New Member
Has done some more logging. It works fine in 5-6 minutes. After thar it starts to get
longer responstimes.
The system has approx 3000 tags. We subscribe about 100. We ge triggered some
times per second. After each trigger there is quit a lot reads to execute the usecase.
Could it be that we have to split the system in 2 or more subsystems to hadle the load?
>Regards owe
