Client supplied certificate instead of username and password
I do not quite understand what you mean. There is just one way to use certificates for user authentication in OPC UA, and that is what the WithX509CertificateIdentity method does.
I will try to set it up here with the Prosys simulation server, and document the steps.
This is the one I am using. it has cert auth. Currently I can not get it to work. I'm probably setting it up wrong.
Which ProsysOPC server you intend to use? I will investigate the same product.
I am still having issues connecting. I have everything in place. it should work.
I too am going to continue this after the holidays. please let me know if you got it working.
I had an initial look. You are right that KepServerEx does not have user authentication via certificates out of the box; but I found this:
support.ptc.com/help/kepware/kepware_server/en/index.html#pa...e/server/uag-certificates.html
So one would have to add the UA Gateway ( www.ptc.com/en/resources/iiot/manufacturing/kepware/infographic/ua-gateway ) possibly?
Kepserver does not support certificate user authentication so i am moving to prosys.
The whole procedure from start to end will be server-dependent. QuickOPC does not really care - it just takes the certificate and uses it for authentication according to UA specs.
However, I am also interested how this works with KepServerEx, so I plan to try it out and document if possible. Please be patient, it may be some days before I get to it, also due to the holiday season.
I am using KepServer right now for testing.
Youre correct to I am looking to authenticate the user with the certificate.
I am still not able to connect, I think I am using the wrong certificate. this question may be beyond the scope of OPCLabs but if you know the answer that would be much appreciated. How does one create a certificate that WithX509CertificateIdentity would accept?
In the remainder of my reply, I assume that you really want to authenticate the *user* using the certificate, and not the OPC UA *application*. OPC UA applications are always authenticated using the certificates, it is unrelated to user authentication, and done differently in QuickOPC. User authentication with certificates is possible, but relatively rare, so that's why I am a little bit concerned about a possible mixup. (Which UA server or PLC are you using?)
The easiest way to authenticate the user with the certificate is to take an existing UAEndpointDescriptor, and create a new one from it using the WithX509CertificateIdentity extension method:
opclabs.doc-that.com/files/onlinedocs/OPCLabs-ConnectivitySt...ndpointDescriptor,String).html
Also see:
opclabs.doc-that.com/files/onlinedocs/OPCLabs-ConnectivitySt...Authentication%20(Client).html
I hope this helps
