- Thank you received: 1
Client supplied certificate instead of username and password
Connor
I just wonder if you had an opportunity to try out what I described in my latest post. Have you made it work, or do you need anything else?
I have documented the code, and steps needed to make it work with Prosys OPC UA Simulation Server, here: kb.opclabs.com/Authenticating_with_OPC_UA_user_certificate_i...rosys_OPC_UA_Simulation_Server
I hope it helps.
I do not quite understand what you mean. There is just one way to use certificates for user authentication in OPC UA, and that is what the WithX509CertificateIdentity method does.
I will try to set it up here with the Prosys simulation server, and document the steps.
This is the one I am using. it has cert auth. Currently I can not get it to work. I'm probably setting it up wrong.
Which ProsysOPC server you intend to use? I will investigate the same product.
I am still having issues connecting. I have everything in place. it should work.
I too am going to continue this after the holidays. please let me know if you got it working.
I had an initial look. You are right that KepServerEx does not have user authentication via certificates out of the box; but I found this:
support.ptc.com/help/kepware/kepware_server/en/index.html#pa...e/server/uag-certificates.html
So one would have to add the UA Gateway ( www.ptc.com/en/resources/iiot/manufacturing/kepware/infographic/ua-gateway ) possibly?
Kepserver does not support certificate user authentication so i am moving to prosys.
