QuickOPC API License
03 Nov 2025 09:45 #14441 by support
Replied by support on topic QuickOPC API License
This seems to be a cross-post with  opclabs.com/forum/opc-wizard/4599-quickopc-branches-browsing#14439 and will be handled there. Please post just once (and it is correct to start a new topic, since this is a  separate issue).
03 Nov 2025 09:03 #14440 by rabbi.mathake
Replied by rabbi.mathake on topic QuickOPC API License
This message contains secure information
29 Oct 2025 13:35 #14438 by rabbi.mathake
Thank you so much for your assistance ,  i managed to browse tags using our old license with  QuickOpc Version 5.61. I was not calling it properly.
29 Oct 2025 07:39 #14437 by support
In order to use version 5.61 you need to install your commercial license key.
The evaluation license key I sent you may also work.
But you have none of that currently, according to the error message.
29 Oct 2025 07:12 #14436 by rabbi.mathake
Browsing worked on the last Quick OPC version , the moment i downgrade to version 5.61  I get this error.
{ "message": "Failed to browse DA OPC Server: Not allowed to run by the license \"Multipurpose\". You might be running a trial license, and the version of the software you are using is obsolete. Obtain a recent version to resolve this problem.\r\nProduct information follows. Component name: \"QuickOPC\", license IDs: \"Multipurpose\", version number: 561, release date: 2021/06/09, trial validity: 397 days, option expression: \"EasyDAClient\".\r\nContext: 0 dropped license(s).\r\n+ The client method called (or event/callback invoked) was 'BrowseNodes'.", "success": false, "statusCode": 400, "result": null }
29 Oct 2025 07:02 #14435 by support
I do not quite understand your question.
All QuickOPC versions support browsing and discovery.
29 Oct 2025 06:46 #14434 by rabbi.mathake
Thank you Received,  Just for confirmation on QUICK OPC   version 5.61  because this is what our current license support.
Can we browse Tag ?
Can we browse server Nodes?
Thank you,
28 Oct 2025 11:11 #14433 by support
The license key can be installed into the registry (e.g. using the License Manager utility), or embedded as a resource into your application (in newest version, also just placed as a file on the disk in a specified directory)..
This is all described in the User's Guide:  opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...html#Licensing%20Elements.html .
I will send you an evaluation license key, valid for 30 days, to the email address you used to register with the Forums.
27 Oct 2025 14:00 #14432 by rabbi.mathake
Thank you,  I will keep on the latest .net 9, so we can also have support when we buy new license.  Do you have any guide on how to properly register QuickOPC License on WebAPI .Net project.  Can you provide any evaluation license for Quick OPC 5.82 with steps on how to set it up on web api project.
27 Oct 2025 13:39 #14431 by support
Each version of our software has an associated supported .NET runtime, OS versions, etc. You can view it here:  kb.opclabs.com/QuickOPC_Versions .
From this table, you can see that the latest version that supported .NET 6 was QuickOPC 2024.2 (5.81). You can still download it, and it will work either with newer commercial license, or with an evaluation license key that I can send to you, free of charge. BUT the fact that this version supports .NET 6 does not mean that WE will support you in case of problems, especially those that can have to do with an unsupported .NET runtime. We do not officially support older versions. So you risk being on your own in such case.
