Error: 6401 after opcServer restore
10 Nov 2025 18:08 #14469 by support
thank you for additional information.
Which QuickOPC version are you running please?
07 Nov 2025 09:52 #14456 by xpycy001
Add more
1) Currently, I am responsible for 4-5 different factories, and two of them have experienced similar situations with their client(opcUa Client, EasyUaClient)
2) Client. exe is unable to automatically reconnect to devices that have been down or shut down for a long time. After target device (opcServer) restarting, the EasyUaClient within client. exe is unable to reconnect successfully
3) when I found cann't reconnect target device, We manually called an API of client.exe, which internally called unsubscribe, forcibly unsubscribed, and then forcibly re subscribed to the target machine, but it was unsuccessful. During the re subscription, we were able to view the subscription handle of the unsubscribe, but we couldn't see any information inside the trace (EasyUAClient. LogEntry output logs couldn't find any clues)
4)On other normal devices, using the client's API to unsubscribe or subscribe again can complete the desired functions normally
07 Nov 2025 09:37 #14454 by xpycy001
cpu & RAM not high, cpu 2~10%, RAM: 400MB, client : about 100  threads ;
I thing :may be some threads have already died
Because these details involve the underlying layer of OpcUA, which may not be in the EasyUaClient layer, I am just guessing for myself. Currently, I am struggling to locate the problem, and there are no target IP related logs for that trace log. This problem has been lingering in practical engineering projects and is very tricky~
23 Sep 2025 08:17 #14378 by support
thank yo for more information, it is helpful.
Please provide some additional info:
1. Is there a high CPU load at the time of the problem?
2. Is there a high network load at the time of the problem?
23 Sep 2025 01:37 #14375 by xpycy001
I found the exception and was unable to reconnect automatically. At the time of discovery, several days had already passed. In this situation, I attempted to cancel and reconnect using the pre developed interface of client. exe (which internally called the Unsubscribed function of EasyUaClient), but both attempts failed. The situations I reported were actual on-site occurrences and I am now seeking your technical support
Simon.Yu
www.vskysoft.com
2025.9.23
10 Sep 2025 12:54 #14360 by support
the error (OpcLabs.UAEngine=6401) can occur when reconnecting to the OPC UA server, e.g. where there is a high load on the system. The system goes through various states after the disconnection and during reconnection, and this can be one of them. When any error happens, however, QuickOPC should retry, and if everything is OK (the server is reachable), the error should go away by itself.
For this reason, I am concerned about the fact that you explicitly unsubscribe after any error. This goes directly *against* the prescribed usage of QuickOPC (see  opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...0OPC%20failure%20recovery.html ). Doing so can easily make matters worse.
Are you saying that without the Unsubscribe, the reconnection would not happen?
If that is the case, you still need to remove the Unsubscribe, and only then we can start troubleshooting why the reconnection has not worked.
10 Sep 2025 03:01 #14359 by xpycy001
Dear support:
I have a question that has been bothering me. I would like to ask for help again. The result of the problem is: Error number 6401
After the abnormal machine was restored, it failed to function normally, and the message "OPC-UA client session is not available when connecting the client subscription" was displayed. ErrorId: OpcLabs.UAEngine=6401
but, UaExpert can instantly connect normally!!!
client.exe appsettng.json parameter of Ua
"OpcUASetting": {
    "RetryConnectDelay": 300,
    "EndpointSelectionTimeout": 30000,
    "SessionConnectTimeout": 20000,
    "SessionParametersRetrialDelay": 60000,
    "OperationTimeout": 20000,
    "CloseTimeout": 5000,
    "ServerShutdownRetrialDelay": 60000
I used the Unsubscrible function of EasyUaClient to unsubscribe from the abnormal point in Opcserver.
 After a delay of 5 minutes, I used the API interface to let Client.exe re-initiate the subscription to the target machine point,
 but still could not restore normal communication.
I'd like to receive official confirmation:
    1) The use of customized communication session and reconnection interval parameters takes into account factors such as the scenario of a single Client.exe connecting to over 300 OpcServers simultaneously and the number of abnormal machines, and is also to ensure that normal machine operation is not affected. However, I'm still unsure whether these customized parameters I'm using locally achieve my desired results, or whether my understanding is correct.
    2) Regarding errors such as "OPC-UA client session is not available when connecting the client subscription."
    ErrorId: OpcLabs.UAEngine=6401," is there a way to manually clear these invalid sessions? I haven't thoroughly read the underlying EasyUaClient source code, so I don't know.
Are there better ways to resolve and clear sessions, allowing these seemingly abnormal machines to reconnect, subscribe, and function?
detail Log info:
I've implemented a client.exe control application using C# and NetCore 8.0, connecting to the IP addresses of over 300 remote Opc Servers. The current problem is: 1) Some OpcServers (remote devices, machines) experience IP communication errors, which are detected as shutdown or network anomalies. This period can be quite long, and the anomalies are clear: some machines on-site are undergoing maintenance, downtime, or power outages. 2) When these few abnormal machines (opc Server IP) have returned to normal, third-party tools can be used to communicate with them normally, but my own Client.exe cannot connect. The following is one of the log snippets
EndpointDescriptor : opc.tcp://10.116.30.162:4840
NodeDescriptor : ns=3;s="Mixed Fluid Data"."DosingManual"[0]."DISet"
StatusInfo : Unknown
StatusCode :
Succeeded : False
DiagnosticsCount : 0
DiagnosticsSummary :
ErrorId : OpcLabs.UAEngine=6401
Exception :
Exception.Message
+ The client method called (or event/callback invoked) was 'DataChangeNotification'.
EndpointDescriptor:opc.tcp://10.116.30.162:4840,NodeDescriptor:NodeId="ns=3;s="Dosing Data"."DosingManual"[0]."DISet""
Because Client.exe cannot be restarted at will,
an internal interface is opened to cancel the subscription of the device with the specified IP,
re-subscribe it again, and try to restore it. However, it still cannot work normally.
When re-subscribing, the subscribledId is also received, and the error is displayed as 6401.
Looking forward to your reply
Simon.Yu
20250910 11:00
