Occasionally Failure OpcLabs.UAEngine=4518 occurs
29 Jul 2025 07:02 #14344 by support
Evaluation key sent by email.
29 Jul 2025 05:04 #14343 by Kärcher
Thanks for the fast reply.
currently we do not have a newer license. It would be great if you could provide an evaluation license.
28 Jul 2025 17:53 #14342 by support
The most likely cause of the error is indicated in the error message - QuickOPC has been performing operations to convert the data, it needed to access the server, and it took longer than expected. So this can be e.g. to some higher load on the server or on the network. Less likely, it can be client side issue (high load on the client computer, or some client-side bug including QuickOPC).
It is currently not possible to change the timeout value, but the current version has it increased to 10 seconds. And there were some other changes (such as referencing newer OPC UA stack), so first step I would recommend is to test with the newest QuickOPC version. If you do not have the license for the newest version and you need an evaluation license (free of charge) to remove the runtime limit of trial-version (30 minutes), let me know.
28 Jul 2025 12:20 - 28 Jul 2025 12:59 #14341 by Kärcher
We have an existing software application that connects to a PLC via OPC-UA-DA ( 5.70.1053). Recently, the error OpcLabs.UAEngine=451 has been reported occasionally.
The exact message is:
"OpcLabs.EasyOpc.UA.Engine.UAEngineException: Timed out waiting (2000 milliseconds) for a session to become available for a conversion."
 I was unable to determine the exact cause of this error.
What could be possible reasons for this error?
What can we do to fix it?
Is this an issue with the library itself, or is it a problem caused by how we are using it?
Would an upgrade to the latest version have any effects to this issue?
Last edit: 28 Jul 2025 12:59 by Kärcher.
