OPC Studio breaks Gitub Copilot in VS 2022
24 Jun 2025 20:04 #14310 by jgyenese
It is inconvenient but not a showstopper.  I can Disable/Enable the extension as needed until a more permanent solution is available.
Thank you!
24 Jun 2025 18:43 #14309 by support
At the bottom of this, it is a conflict of assembly versions between the QuickOPC extension, and the remainder of Visual Studio/other extensions. Unfortunately, QuickOPC has to (transitively) reference a huge number of assemblies (from the UA stack, for example), which increases the probability of it happening.
Unfortunately, resolving is is extremely demanding - basically, the only solution is to move as much as possible into a separate process or appdomain, where it cannot cause conflicts, and maintain a communication between the "resident" and "out-of-process" parts.
We already have something in the works, but it is not coming any time soon.
The Visual Studio extension is only necessary in design-time, for the Toolbox items (dragging to Windows Forms), and Live Binding (also WIndows Forms). So disabling or uninstalling in case of conflict should not cause problem to most users. I hope you are among those, - until we have a solution.
The following user(s) said Thank You: Nowok
20 Jun 2025 15:46 #14306 by jgyenese
I can confirm that disabling the "OPC Studio" extension in VS 2022 does indeed allow GitHub Copilot to function properly.
The only problem is that the OPC Studio toolbox items are no longer available.
20 Jun 2025 10:12 #14305 by Nowok
I can confirm the same issue. No problem on old computer configuration but as I've been configuring a new computer I faced the same issue after installation of OPC Studio extension. If I disable this extension no more error. I tried to uninstall and reinstall extension - no luck, still getting this error making Copilot crash:
The 'ConversationsPackage' package did not load correctly.
The problem may have been caused by a configuration change or by the installation of another extension. You can get more information by examining the file 'C:\Users\mnowok\AppData\Roaming\Microsoft\VisualStudio\17.0_17c09894\ActivityLog.xml'.
Restarting Visual Studio could help resolve this issue.
20 Jun 2025 06:40 #14304 by support
For start, please check whether the OPC Studio extension for Visual Studio is still installed, and if so, uninstall it: See  opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...sual%20Studio%20Extension.html .
The Visual Studio is the only way the OPC Studio can "permanently" affect how Visual Studio behaves.
19 Jun 2025 19:56 #14303 by jgyenese
I have been trying to track down a problem with Github Copilot not working, and I traced the issue to OPC Studio.  I have reproduced the issue using the following steps.
1.  I started with a fresh install of Windows 11 Pro and used Windows Update to install all updates.  Windows version is 24H2.
2.  Install Visual Studio 2022 Community with MAUI, .NET Desktop, and WinUI application workloads selected.  Visual Studio version is 17.14.6.
3.  Launch VS and login to Visual Studio and Github accounts - Github copilot is working - green checkmark and chat window working.
4.  Install OPC Studio 2025.1 and accept all of the default options.
5.  Launch VS.  I get the following error message: The 'ConversationsPackage' package did not load correctly.
     Github Copilot not working - no green checkmark and chat windows says "Something went wrong.  We're sorry, the Github Copilot service is temporarily unavailable."
Uninstalling OPC Studio does NOT fix the Github Copilot problem.
Any help would be greatly appreciated.
