How read Int32 data from PrimitiveData in StructuredData
19 Nov 2024 08:36 #13288 by support
It is clear from the exception that the data type of the variable is not Int32, but rather an enumeration.
So, instead of casting the fieldData [] to PrimitiveData, cast it to EnumerationData. If you are interested in the numerical value, take e.g. its Int32Value property then:
opclabs.com/files/onlinedocs/OPCLabs-OpcStudio/Latest/User%2...numerationData_properties.html
You can also obtain ValueName etc.
I hope this helps
The following user(s) said Thank You: Fils72
19 Nov 2024 07:41 #13287 by Fils72
this is the Exception when i try to read this node :
_PlanState = Int32.Parse(((PrimitiveData)fieldData["PlanState"]).Value?.ToString() ?? "0");
************** Exception Text **************
System.InvalidCastException: Unable to cast object of type 'OpcLabs.BaseLib.DataTypeModel.EnumerationData' to type 'OpcLabs.BaseLib.DataTypeModel.PrimitiveData'.
at OpcLab_Test.Form1.button4_Click(Object sender, EventArgs e) in C:\Users\ethica.software\source\repos\OpcLab_Test\OpcLab_Test\Form1.cs:line 172
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.3062.0 built by: NET472REL1
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
OpcLab_Test
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///Z:/aaaa/OpcLab_Test.exe
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
OpcLabs.EasyOpcUA
Assembly Version: 5.80.347.1
Win32 Version: 5.80.347.1
CodeBase: file:///Z:/aaaa/OpcLabs.EasyOpcUA.DLL
OpcLabs.BaseLib
CodeBase: file:///Z:/aaaa/OpcLabs.BaseLib.DLL
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Core
Win32 Version: 4.7.3081.0 built by: NET472REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml.Linq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
OpcLabs.EasyOpcUAComponents
CodeBase: file:///Z:/aaaa/OpcLabs.EasyOpcUAComponents.DLL
Opc.Ua.Core
Assembly Version: 1.5.374.0
Win32 Version: 1.5.374.78
CodeBase: file:///Z:/aaaa/Opc.Ua.Core.DLL
Opc.Ua.Client
CodeBase: file:///Z:/aaaa/Opc.Ua.Client.DLL
Microsoft.Extensions.FileProviders.Abstractions
Assembly Version: 6.0.0.0
Win32 Version: 6.0.21.52210
CodeBase: file:///Z:/aaaa/Microsoft.Extensions.FileProviders.Abstractions.DLL
Microsoft.Extensions.Primitives
CodeBase: file:///Z:/aaaa/Microsoft.Extensions.Primitives.DLL
Opc.Ua.Configuration
18 Nov 2024 19:27 #13286 by support
Please post here the details of the error (full ands precise error message, the call stack, and if there is an .InnerException, then its details as well).
18 Nov 2024 17:10 #13285 by Fils72
I'm reading array-type variables, using Structured Data as a primitive.
reading the value of the string array causes no problems, but reading a subsequent Int32 node causes an error.
This is my code to read both the string and int32 array value:
foreach (var value in bundleInfoArray)
//bundleInfoArray.Length
if (!(value is UAGenericObject bundleInfo))
continue;
var fieldData = (((StructuredData)bundleInfo.GenericData)?.FieldData);
if (fieldData is null)
continue;
var _JobGuid = ((PrimitiveData)fieldData["JobGuid"]).Value?.ToString(); <
HERE OK
_PlanState = Int32.Parse(((PrimitiveData)fieldData["PlanState"]).Value?.ToString() ?? "0"); <
HERE ERROR
Where am I going wrong?
