Incorrect behavior on production clients
11 Nov 2024 14:41 #13270 by support
Thank you for the answers, I think that it is now clear to me what you are doing.
It is likely that there is an error during writing (and maybe during reading/subscriptions as well) in the production environment - you just do not see it, because you have not set up the application to handle it.
Please read this: opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...del%20in%20Live%20Binding.html . There are types of errors described (I / II / III) and how to handle them; however, in your case, the most likely cause is described in the (unnumbered) last paragraph. In order to visualize such errors, add some text box/text boxes to your screen, and bind them to the *same* OPC node as you are reading/writing, but this time setting the Kind to ErrorMessage ( opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...rame.html#Mapping%20Kinds.html ). This will cause any error message associated with the operations to appear in the additional text box.
I should also say that in general, binding both directions (writes, and reads+subscriptions) with "All" to the same control is tempting, but has all kinds of issues related to it. Possibly even more so, if you specify the write event source as "ValueChange" on the same control. Every change (most keystrokes) in the control will then trigger the write, which will then - when successful, and with some delay - update the control again. This may result in "flickering" or other issues.
11 Nov 2024 08:36 #13268 by Roccioletti
ok, let's start from the beginning. First things I know:
1) C# application with VS2022 works as expected if running on the development machine
2) the same application does not run as expected on the production machine
3) the trivial application reads a counter from a PLC and writes a variable to the PLC
4) the counter is read by both machines simultaneously without problems.
5) I have to send a command to the PLC and write a variable, I read this same variable and subscribe to it. In the development machine I write the variable and the subsequent reading of the same confirms the writing in the PLC. The machine understands and starts working. In the production machine I write the same variable and the subsequent reading returns 0. I write 2 and read 0 and the machine does not start working.
For reading and writing I use the "Live binding" technique and I can't find a way to insert error checking. I attach an explanatory screenshot.
It is also true that it is the first time I have used this library and perhaps I am not making the best use of the product.
    04 Nov 2024 16:20 #13261 by support
    I do not quite understand your description (e.g. what do you mean by "value.... is deleted", "does not appear" - appear where?, "I ... see the value" - see where?). But for myself I have summarized as "you call the Write, but it does not happen, and there is no error reported". If I have incorrect understanding, please elaborate precisely on what you are doing and what is happening.
    If my understanding is correct, then the first question actually is: If there *was* an error reported during the Write, would you know about it? That is, do you have th eproper error handling core around the calls to QuickOPC methods? For example, if you are using the EasyUAClient.WriteValue method, this method would thrown a UAException n case of a problem. Do you have a code to catch, handle, and report such exception? If so, can you post the skeleton of such code here?
    04 Nov 2024 14:28 #13259 by Roccioletti
    I don't have an error, but while on the development machine if I write a field, which I process both in reading and writing (all), the field maintains the written value, on the production machine it is immediately deleted or in any case does not appear, while I continue to see the written value. I understand that I'm describing an absurd situation but that's what happens.
    I can somehow collect any errors that are generated during the execution of the program, errors which in this case do not appear on the screen. Clearly I am talking about errors in communication with the machine via OPC.
    04 Nov 2024 13:58 #13258 by support
    This is not related to licensing.
    If you are getting an error upon writing, please provide the full error message.
    04 Nov 2024 12:02 #13257 by Roccioletti
    hello,
    I detect a difference in the behavior of the application running on the development machine compared to the behavior on the target client.
    The license is activated on the client using LMconsole.
    Specifically in the production client I can read but not write. Could it be a problem with the license not being installed correctly? even if LMconsole does not detect any problems.
    Time to create page: 0.294 seconds
