WinIOError errorcode: 6 and BadSecureChannelClosed errors after a simple Read
22 Oct 2024 17:15 #13231 by support
In the code we write, we generally do not throw exceptions that we later catch.
This is all in the code written by somebody else (Opc.Ua.Core is by OPC Foundation)..
22 Oct 2024 16:52 #13230 by SZL
Hello!
Thank you! The first error indeed coming outside the OPC modules, but the second is coming from OpcUaCore.dll.
It is strange that the OPC ReadValue method call causes the problem.
Normally it wouldn't bother me, but handling 4 try..catch per call slows down the reading process a lot.
BR, SZL
22 Oct 2024 16:05 #13229 by support
Are you reporting exceptions that thrown internally, but do not actually propagate out of QuickOPC method calls?
If this is the case, they are none of your concern and you should ignore them.
22 Oct 2024 10:56 #13228 by SZL
I have only one line of code:
var z0 = EasyUAClient.SharedInstance.ReadValue("opc.tcp://opcua.demo-this.com:51210/UA/SampleServer", "nsu=http://test.org/UA/Data/ ;i=10854");
When I execute this line in a WinForms Net Framework 4.8 project I got 4 (2x2) errors:
- First error: Descriptor is invalid. (IOException). Errorcode: 6
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) in System.IO\__Error.cs:line 167
This throws two times.
- Second error: BadSecureChannelClosed at Opc.Ua.Bindings.TcpAsyncOperation`1.End(Int32 timeout)
This also throws two times.
After these errors when I continue the code execution the Read operation reads the value successfully and I have the result.
Why these errors are happen before read? When I read again the errors throws also again.
I attach images from the errors:
Quickopc versions.
Thank you for help!
    Time to create page: 0.171 seconds
