Certificate "CN=" not found in certificate store of store type 'Directory'
10 Jun 2024 15:28 #12863 by support
Many thanks!
I was able to reproduce the issue with your project. For whatever reason, the FileVersionInfo.FileDescription returns a string with a single space character in it, and when we attempted to use it as the certificate common name, it did not go well.
In QuickOPC 2024.2 this will be fixed (will not require you to set the ApplicationName in the code).
10 Jun 2024 12:27 #12862 by CFrayneIonic
I've sent a google drive link through email.
09 Jun 2024 07:56 #12861 by support
interestingly enough, I could not reproduce the issue, in order to do the internal fix I wanted. In fact it looks like that the CN is perhaps not empty, but it might consist of some invisible special characters - but that is just a wild guess. Can you perhaps send me the project that shows the problem, or one of the improperly generated certificates, or both? If deemed confidential, you can email to support09 (at) opclabs.com.
Thank you, and best regards
07 Jun 2024 10:14 - 07 Jun 2024 10:15 #12858 by support
Thank you. I was heading in this direction; I just wanted to collect enough information upfront.
I still consider this a problem in QuickOPC, and we will look into it and fix into the next version. The expected behavior is that although you can always configure the subject name, you should not be required to do so, and QuickOPC should automatically come up with some non-empty, and generally valid name.
Thank you for reporting this.
Last edit: 07 Jun 2024 10:15 by support.
06 Jun 2024 16:48 #12855 by CFrayneIonic
Issue was resolved, The certs no longer generate empty as I've set the application Paramters.
Thank you!
06 Jun 2024 12:05 #12854 by CFrayneIonic
Yes, a Windows Forms app
05 Jun 2024 20:14 #12852 by support
Thank you for the additional information. If your project is a Class Library, it cannot be run standalone. So, my question actually is, what type of project is the the actual top-level application that is experiencing the problem? Is it Windows Forms application, or something else?
05 Jun 2024 19:50 #12851 by CFrayneIonic
1. I'm using VB.NET
2. No it's a class Library
3. No
4.
5. Debugging from VS
    05 Jun 2024 19:26 #12850 by support
    thank you for the detailed report. I can *guess* that the problem is coming from the fact the the certificate common name (CN) is actually empty. The fact that this causes some subsequent issues isn't surprising that much; we need to determine why the common name came out empty, and how to rectify that, first.
    Can you please answer some additional questions:
    1. Which programming language are you using? C#? VB.NET?
    2. Is the main ("true") project also Windows Forms app?
    3. Are you setting any parameters inside QuickOPC ApplicationManifest? ( opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...%20Application%20Manifest.html )
    4. What are the settings of the assembly-level attributes (in C#, usually in Properties/AssemblyInfo.cs ), if any - such as [AssemblyTitle] - can you post them here?
    5. Are you starting your application normally (e.g. from VS IDE, or clicking on the EXE in the File Explorer), or in some special way?
    05 Jun 2024 18:01 #12848 by CFrayneIonic
    I just realized there might be confusion, the exception text is from a test project that I wrote that throws the exact same exceptions as the my main project, here's the exception text for the actual project
    OPC UA service result - {Bad}. The operation failed. Client application certificate "CN= " not found in certificate store of store type 'Directory' with store path "C:\Users\Connor.Frayne\Documents\SafeBoxHMI\SafeBox\bin\Debug\net8.0-windows/OPC Foundation/CertificateStores/MachineDefault". OpcLabs.EasyOpc.UA.UAEngineBase Error: 0 : UAClientSubscription failed at tick 443933218 and will retry in 3000 ms OPC-UA client session is not available when connecting the client subscription. + The client method called (or event/callback invoked) was 'DataChangeNotification'.
