System.MissingMethodException in OPC-UA
29 May 2024 19:39 #12819 by support
Oh, this is great to know, thanks for letting me know so quickly.
29 May 2024 19:18 #12818 by CFrayneIonic
Issue was found in NuGet Packages.
Thank you very much.
29 May 2024 19:04 #12817 by support
so far I was not able to reproduce the problem.
I suspect, however, some kind of mixup in assembly/package references. Can you please check that you do not have some additional UA-related assemblies or NuGet packages referenced?
If you do not find anything suspicious, can you send me your .csproj file? Either post it here, or, if it is confidential, email to support09 (at) opclabs.com?
Many thanks
The following user(s) said Thank You: CFrayneIonic
29 May 2024 16:12 #12816 by CFrayneIonic
1. It continues to run however none of the nodes are acquired.
2. I've ran examples from the user guide completely fine in a different solution.
3. Yes I believe so, OPCLabs QuickOPC 2023.1
4. I never ran the program on the old version as it had many errors
5. Windows Forms App
29 May 2024 15:40 #12815 by support
Can you please provide some additional information?
1. Is your program able to continue normally after the exception is thrown (i.e. it is handled somehow), or is the exception unhandled?
2. Have you tried to open projects (for OPC UA) from the example solutions, and run them (if not, please do so) - do they also have the same problem?
3. Have you been using a previous version of QuickOPC on the same computer before?
4. If so, is it so that the same program has worked with earlier version but now it does not? Or is this a new program, only tested with this new QuickOPC version?
5. What type of project is your program? (e.g. console app, Windows Forms app, Web app, Web service, Windows service, ...)
29 May 2024 14:58 #12814 by CFrayneIonic
I'm modifying a program that uses QuickOPC. Every time I run the code, a System.MissingMethodException is thrown(pasted below). The code is supposed to subscribe to multiple Nodes. I'm currently running on a evaluation license for QuickOPC Ultimate.
Visual Studio Version: 17.10.0
.net Framework Installed: net8.0
Target Framework: net8.0
NuGet Package: OPCLabs.QuickOpc v5.80.192
OPC version: 2024.1
OpcLabs.EventTracing.LogEntries Error: 1 : LogEntry("OPCLabs-UAEngine",Error,0,1). INTERNAL ERROR. The OPC-UA engine might be in an unstable state. An exception of type "System.MissingMethodException" from source "OpcLabs.EasyOpcUA" has occurred in OPC-UA SDK action 'ApplicationInstance.CheckApplicationInstanceCertificate'. The exception descend follows. (0) System.MissingMethodException OpcLabs.EasyOpcUA (<InnerValidateOrCreateOwnCertificate>b__0) -> Method not found: 'System.Threading.Tasks.Task`1<Boolean> Opc.Ua.Configuration.ApplicationInstance.CheckApplicationInstanceCertificate(Boolean, UInt16, UInt16)'. at OpcLabs.EasyOpc.UA.Toolkit.ClientServer.SdkApplicationConfigurationClientServerApplication.<>c__DisplayClass42_0.<InnerValidateOrCreateOwnCertificate>b__0() at OpcLabs.EasyOpc.UA.Toolkit.UAEngineBase.PerformSdkAction(UASdkCallType callType, Func`1 usingFunction, String name, Action sdkAction) OpcLabs.EasyOpc.UA.UAEngineBase Critical: 0 : Error "The source was not found, but some or all event logs could not be searched. To create the source, you need permission to read all event logs to make sure that the new source name is unique. Inaccessible logs: Security, State." writing 'Error' entry from source 'OPCLabs-UAEngine' to the event log: Internal error (only first occurrence is logged), process "SafeBox" Id 16496, current application domain "SafeBox" Id 1, entry assembly "SafeBox, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null": An exception of type "System.MissingMethodException" from source "OpcLabs.EasyOpcUA" has occurred in OPC-UA SDK action 'ApplicationInstance.CheckApplicationInstanceCertificate'. The exception descend follows. (0) System.MissingMethodException OpcLabs.EasyOpcUA (<InnerValidateOrCreateOwnCertificate>b__0) -> Method not found: 'System.Threading.Tasks.Task`1<Boolean> Opc.Ua.Configuration.ApplicationInstance.CheckApplicationInstanceCertificate(Boolean, UInt16, UInt16)'. at OpcLabs.EasyOpc.UA.Toolkit.ClientServer.SdkApplicationConfigurationClientServerApplication.<>c__DisplayClass42_0.<InnerValidateOrCreateOwnCertificate>b__0() at OpcLabs.EasyOpc.UA.Toolkit.UAEngineBase.PerformSdkAction(UASdkCallType callType, Func`1 usingFunction, String name, Action sdkAction)
