Error While Connecting to the Server
06 May 2024 13:00 - 06 May 2024 13:15 #12760 by Jannie@Moore
Hi there, I get this error 'An item with the same key has already been added. Key: Underflow'
on this line categoryElements = client.QueryEventCategories("", "Matrikon.OPC.GDA.1");
i have this server Matrikon.OPC.GDA.1 running and i have few Alarm Events configured.
When running the following code
using System; using System.Collections.Generic; using System.Diagnostics; using System.Net; using System.Reflection.Metadata; using OpcLabs.EasyOpc.AlarmsAndEvents; using OpcLabs.EasyOpc.AlarmsAndEvents.AddressSpace; using OpcLabs.EasyOpc.AlarmsAndEvents.OperationModel; using OpcLabs.EasyOpc.OperationModel; namespace OPCAETest { internal class Program { static void Main(string[] args) { // Instantiate the client object. var client = new EasyAEClient(); AECategoryElementCollection categoryElements; try { categoryElements = client.QueryEventCategories("", "Matrikon.OPC.GDA.1"); } catch (Exception Exception) { Console.WriteLine("*** Failure: {0}", Exception.InnerException.Message); return; } //catch (OpcException opcException) //{ // Console.WriteLine("*** Failure: {0}", opcException.GetBaseException().Message); // return; //} foreach (AECategoryElement categoryElement in categoryElements) { Debug.Assert(categoryElement != null); Console.WriteLine("Category {0}:", categoryElement); foreach (AEAttributeElement attributeElement in categoryElement.AttributeElements) { Debug.Assert(attributeElement != null); Console.WriteLine(" Information about attribute {0}:", attributeElement); Console.WriteLine(" .AttributeId: {0}", attributeElement.AttributeId); Console.WriteLine(" .Description: {0}", attributeElement.Description); Console.WriteLine(" .DataType: {0}", attributeElement.DataType); } } var eventHandler = new EasyAENotificationEventHandler(aeClient_Notification); client.Notification += eventHandler; // Keep the application running Console.WriteLine("Press any key to exit..."); Console.ReadKey(); } // Notification event handler static void aeClient_Notification(object sender, EasyAENotificationEventArgs e) { if (!e.Succeeded) { Console.WriteLine("*** Failure: {0}", e.ErrorMessageBrief); return; } if (!e.Refresh && (!(e.EventData is null))) { // Display all received event attribute IDs and their corresponding values Console.WriteLine("Event attribute count: {0}", e.EventData.AttributeValues.Count); foreach (KeyValuePair<long, object> pair in e.EventData.AttributeValues) Console.WriteLine(" {0}: {1}", pair.Key, pair.Value); } } } }
Last edit: 06 May 2024 13:15 by support.
Time to create page: 0.204 seconds
