OPC Server Properties
02 May 2024 14:47 #12756 by support
Replied by support on topic OPC Server Properties
Unless the server implemetation is screwed up, you should be able to obtain the individual pieces. Some of them are defined by OPC A&E, some of them might be server-specific, so-called attributes.
Read:
- opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...ts.AEEventData_properties.html (shows which info is available with each event)
- opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...%20an%20event%20attribute.html (shows how to browse for the attributes)
- opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...ieve%20attribute%20values.html (shows how to specify which additional attributes should be delivered with the events)
Please start a new topic on the forums when you have a new question. Do not put more and more unrelated questions to a topic that was started for something else.
The following user(s) said Thank You: Jannie@Moore
02 May 2024 11:49 #12755 by Jannie@Moore
Replied by Jannie@Moore on topic OPC Server Properties
Hi , I was using third party OPC Explorer, so what im asking is, Is it gonna display that way when i use QuickOPC API, or i will be able to get values per attributes.
here is an example of the value in OPC Explorer.
1234 Overview\093LSD1083/1 2016-09-15 06:51:44.267 AM Oil Lvl High High Alarm at 78.00 4 -2147483648 64 Level Warning High 192 Yes 2016-09-15 06:51:44.267 AM 704843766 129 3 IEVENT ACTIVE TIME =15/09/2016 06:51:44 IEVENT UNIQUE EVENT ID =633043064636781,5889 IEVENT COMMENT = IEVENT SUBCONDITION NAME =Warning High IEVENT CONDITION NAME =Level IEVENT CATEGORY DESCRIPTION =Level IEVENT CATEGORY ID =-2147483648 IEVENT SEVERITY =64 IEVENT TYPE =32 CLASSNAME =Warning TYPENAME =Warning High FORECOLOR =255 BACKCOLOR =16777215 FLASHCOLOR =16777215 FLAGS =13631557 TEXT01 =043LST1003/1 TEXT02 =TS Oil Overview TEXT03 = Oil Lvl High High Alarm at 78.00 TEXT04 = TEXT05 = TEXT06 = TEXT07 = TEXT08 = TEXT09 = TEXT10 = PROCESSVALUE01 =78 PROCESSVALUE02 =0 PROCESSVALUE03 =0 PROCESSVALUE04 =29 PROCESSVALUE05 = PROCESSVALUE06 = PROCESSVALUE07 = PROCESSVALUE08 = PROCESSVALUE09 = PROCESSVALUE10 = STATETEXT =C INFOTEXT = LOOPINALARM =704843766 CLASSID =2 TYPEID =19 MODIFYSTATE =65537 AGNR =0 CPUNR =0 DURATION =0 COUNTER =2257 QUITSTATETEXT =QS QUITCOUNT =1523 PARAMETER =1166 BLOCKINFO = ALARMCOUNT =2222 LOCKCOUNT =0 PRIORITY =1 APPLICATION = COMPUTER = USER = COMMENT = HIDDEN-COUNT =0 BIG COUNTER =633043064636781,5889 OS-HIDDEN =False OS EVENTID =704843766 OPCSTATE ENABLED=true ACTIVE=true ACKED=false OPCCHANGED ACTIVE_STATE=true ACK_STATE=false ENABLE_STATE=false QUALITY=false SEVERITY=false SUBCONDITION=false MESSAGE=false ATTRIBUTE=true
02 May 2024 10:38 #12754 by support
What do you mean that it is received as a string? Please post here the code you use to process/display the event.
02 May 2024 09:03 #12753 by Jannie@Moore
Hi, on OPC Classic A&E. when receiving data it is received as single string that contain the following about the event.
 Event type
 Severity
 Category
 Area
 Code
Using QuickOPC is it possible to filter this attribute from the string. if so please provide an example.
02 May 2024 06:19 #12752 by Jannie@Moore
01 May 2024 10:18 #12749 by support
This is globally on the server. Here is the requested example:
// This example shows how to read the build information of the server. // See also: https://reference.opcfoundation.org/Core/Part5/v105/docs/7.7 and // https://reference.opcfoundation.org/Core/Part5/v104/docs/12.4 . // // Find all latest examples here: https://opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Latest/examples.html . // OPC client and subscriber examples in C# on GitHub: https://github.com/OPCLabs/Examples-QuickOPC-CSharp . // Missing some example? Ask us for it on our Online Forums, https://www.opclabs.com/forum/index ! You do not have to own // a commercial license in order to use Online Forums, and we reply to every post. using System; using OpcLabs.BaseLib.OperationModel; using OpcLabs.EasyOpc.UA; using OpcLabs.EasyOpc.UA.AddressSpace.Standard; using OpcLabs.EasyOpc.UA.OperationModel; namespace UADocExamples.InformationModel { partial class BuildInfoType { public static void Main1() { UAEndpointDescriptor endpointDescriptor = "opc.tcp://opcua.demo-this.com:51210/UA/SampleServer"; // or "http://opcua.demo-this.com:51211/UA/SampleServer" (currently not supported) // or "https://opcua.demo-this.com:51212/UA/SampleServer/" // Instantiate the client object. var client = new EasyUAClient(); // Obtain values. By default, the Value attributes of the nodes will be read. var readArgumentsArray = new[] { new UAReadArguments(endpointDescriptor, UAVariableIds.ServerStatusType_BuildInfo_BuildDate), new UAReadArguments(endpointDescriptor, UAVariableIds.ServerStatusType_BuildInfo_BuildNumber), new UAReadArguments(endpointDescriptor, UAVariableIds.ServerStatusType_BuildInfo_ManufacturerName), new UAReadArguments(endpointDescriptor, UAVariableIds.ServerStatusType_BuildInfo_ProductName), new UAReadArguments(endpointDescriptor, UAVariableIds.ServerStatusType_BuildInfo_ProductUri), new UAReadArguments(endpointDescriptor, UAVariableIds.ServerStatusType_BuildInfo_SoftwareVersion), }; ValueResult[] valueResultArray = client.ReadMultipleValues(readArgumentsArray); // Display results. for (int i = 0; i < valueResultArray.Length; i++) { UAReadArguments readArguments = readArgumentsArray[i]; ValueResult valueResult = valueResultArray[i]; if (valueResult.Succeeded) Console.WriteLine($"{readArguments.NodeDescriptor.NodeId}: {valueResult.Value}"); else Console.WriteLine($"{readArguments.NodeDescriptor.NodeId}: *** Failure: {valueResult.ErrorMessageBrief}"); } // Note that as of time of writing this code, the public sample server does not have the build information // filled in, and the displayed information is thus largely empty (but correct). The example gives better // results with servers that provide meaningful build information. } } }
30 Apr 2024 12:18 #12747 by Jannie@Moore
Thank you, Do you have any example of code available on the site for that purpose. is it available as part of tag properties . or is strictly on the server properties?
30 Apr 2024 07:44 - 30 Apr 2024 07:45 #12745 by support
OPC Classic Alarms&Events, and OPC UA Alarms&Conditions are supported:
- opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...for%20OPC%20Classic%20A&E.html
- opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...20Alarms%20&%20Conditions.html
In OPC UA, every OPC server exposes information about itself in nodes in the Address Space, that can be read as any other nodes.
Last edit: 30 Apr 2024 07:45 by support.
30 Apr 2024 06:09 #12744 by Jannie@Moore
Hi, we using QuickOPC using .NET to collect OPC UA and OPC DA data, soon we will be Adding Alarm and Events. Using QuickOPC we want to be able to collect data for mentioned properties also.
29 Apr 2024 14:59 #12739 by support
I suppose this question is about OPC Classic (COM/DCOM) servers, as the category says. If not (and it is OPC UA), let me know, because the answer will be somewhat different.
For OPC Classic, most of the information you mentioned can be obtained from the server using the OPCServer::GetStatus call. However, QuickOPC does not provide this to your code. Some server may also expose it through OPC items, that would work but will be vendor-specific.
