Migrating from EasyOPC.NET 5.2 to OPC Studio 2024.1
22 Feb 2024 10:10 #12581 by support
thanks for the good news.
The actual numerical code for a Quality with WaitingForInitialData is 32.
21 Feb 2024 16:48 #12580 by tlaford
Thank you for the quick reply.
I made the changes you suggested and I replaced DAQualities.WaitingForInitialData with 0, all the compile errors are gone, and the updated program seems to run fine.
21 Feb 2024 16:28 #12579 by support
Re 2. In newer QuickOPC versions, you cannot reference the assemblies directly and individually. You need to reference the NuGet package.
- opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...NuGet%20Packages%20(.NET).html
- opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...es%20in%20Visual%20Studio.html
Re 3. DAQualities.WaitingForInitialData
Re 4. Instead of "If (e.ErrorCode <> 0) Then", use "If (Not e.Succeeded) Then"
Re 1. The auto-subscribing has been reworked, and there is no direct equivalent for UpdateRates.ReadAutomatic / WriteAutomatic. Most likely you can leave this part out completely. More info:
- opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...6e-3005-433e-b390-db063ef54d51
- opclabs.doc-that.com/files/onlinedocs/OPCLabs-OpcStudio/Late...cribingParameters_members.html
21 Feb 2024 16:12 #12578 by tlaford
I am trying to migrate my code from an antique 2012 version (EasyOPC.NET 5.2) to the modern version (OPC Studio 2024.1) and I could use a little help.
My project is written using Visual Studio 2017 in Visual Basic with .Net Framework 4.7.2. It subscribes to a number of tags on multiple machines and when a tag changes value the program receives a EasyDAItemChangedEvent
I have removed the reference to the old OpcLabs.EasyOpcClassic and added references to the following libraries:
  • OpcLabs.BaseLib
  • OpcLabs.EasyOpcClassic
  • OpcLabs.EasyOpcClassicComponents
  • OpcLabs.EasyOpcClassicCore
I have changed the OpcLabs.EasyOpc.DataAccess.EasyDAItemChangedEventArgs to OpcLabs.EasyOpc.DataAccess.OperationModel.EasyDAItemChangedEventArgs
I updated Timeouts and HoldPeriods from EasyDaClient to EasyDaClient.InstanceParameters
I updated State and ItemDescriptor from EasyDAItemChangedEventArgs to EasyDAItemChangedEventArgs.Arguments
But the following errors still remain:
  1. UpdateRates is not a member of EasyDaClient
  2. Reference required to assembly 'Microsoft.Extensions.Configuration.Abstractions, Version=6.0.0.0, ...' containing the type 'IConfiguration'.
  3. WaitingForInitialData is not a member of DAQuality
  4. ErrorCode is not a member of EasyDAItemChangedEventArgs
Here are some code snippets where the errors occur:
Me.OpcConnection = New OpcLabs.EasyOpc.DataAccess.EasyDAClient(Me.components) Me.OpcConnection.UpdateRates.ReadAutomatic = 10000 Me.OpcConnection.UpdateRates.WriteAutomatic = -1 ... Private Quality_ As DAQuality Quality_ = DAQuality.WaitingForInitialData ... Private Sub ProcessItemChanged(ByVal e As OpcLabs.EasyOpc.DataAccess.OperationModel.EasyDAItemChangedEventArgs) ' Display any errors If (e.ErrorCode <> 0) Then EventLog("OPC ERROR: " & e.Arguments.State.ToString() & " - " & e.Arguments.ItemDescriptor.ItemId & " " & e.ErrorMessage) Return End If
Could someone offer any insight into how to handle these remaining compile errors?
Time to create page: 0.206 seconds
