Can I read a value at a specified date/time?
14 Feb 2024 17:26 #12554 by support
No, we do not (and to make it clear, we currently do not support the HDA part of OPC UA either).
14 Feb 2024 16:23 #12553 by ScottEwine
Do you have any tools that support HDA, I know the customer's server supports it, I do not want to use UA.
Scott
14 Feb 2024 16:16 #12552 by support
No, OPC DA (Data Access) does not have that.
What you are asking for is possible using OPC HDA (Historical Data Access), and a corresponding functionality in the newer OPC UA specs.
But the OPC HDA spec must be supported by the server (not so common!), and, QuickOPC does not support OPC HDA.
The following user(s) said Thank You: ScottEwine
14 Feb 2024 16:12 #12551 by ScottEwine
Good Morning,
I would like to read the value if an item at a specified date/time to load historical data into another system, something like this, where I specify an additional parameter:
dAVtq = easyDAClient1.ReadItem(MachineName, ServerName, ItemID ,dateTime );
Is this possible?
Thanks, Scott
