Unable to connect to Kep Server EX
11 Dec 2023 13:10 #12468 by support
Something must have changed externally to the your app or Conn.Explorer. I do not know what.
09 Dec 2023 15:11 #12465 by micham
Thank you for your answer. See my answers below.
5. Right-click on this new node, and select Ping Host Test. What is the outcome? - Success.
6. Right-click on this new node again, and select "TCP Connect Test". What is the outcome? - Success.
7. Right-click on this new node again, and select "Server Connection Test". What is the outcome? - Success.
After doing the above, I was able to connect from my client! Do you understand what made it work?
    05 Dec 2023 07:57 #12445 by support
    In order to get more information, can you please:
    1. Start the Connectivity Explorer application installed with QuickOPC.
    2. In Point Editor window, double-click the item "< Double-click to: Add OPC UA Endpoint >".
    3. Enter the endpoint URL, precisely as you are using it in your program, and press Enter.
    4. At this point you will probably get a little red triangular error added to the node. Did it appear? If so, ignore it.
    04 Dec 2023 16:08 #12443 by micham
    Yes.
    04 Dec 2023 09:07 #12429 by support
    This looks like a low-level inability to connect to that endpoint/port.
    Was the test with UAExpert made from the same machine as the one where your client is running?
    01 Dec 2023 16:31 #12423 by micham
    The installed NuGet version is 5.71.401.
    01 Dec 2023 14:51 #12421 by micham
    We are unable to connect to Kep Server EX (UA) when trying to browse. The following error is displayed:
    OPC UA service result - Error establishing a connection: BadNotConnected.
    I don't see any rejected certificates when I click on the Move button (in the OPC UA Configuration Helper)
    When connecting from UA Expert using the same endpoint and the same user name and password, there is no problem.
    Exception details:
    OpcLabs.EasyOpc.UA.Engine.UAEngineException: UA SDK error (Opc.UA.ServiceResult=0x808A0000) in 'DiscoveryClient.GetEndpoints'. OPC UA service result - Error establishing a connection: BadNotConnected.
    + The error occurred when preselecting an endpoint for discovery URL "opc.tcp://mike2022:49320".
    + Connection attempt #1; last connected at 1/1/0001 12:00:00 AM (local); unconnected for 00:00:00.
    + Some possible causes of this error are that the OPC-UA server is not running, or is not configured to listen on the specified port. Also, the network connection may be broken (cable unplugged?).
    + The client method called (or event/callback invoked) was 'BrowseMultiple[1]'. ---> OpcLabs.EasyOpc.UA.UAServiceException: OPC UA service result - Error establishing a connection: BadNotConnected.
    Activity Trace:
    Following (5) events were gathered during the action on activity ID [39], in the order of first occurrence:
    SDK trace: GetEndpoints Called. RequestHandle=1, PendingRequestCount=1
    SDK trace: ChannelId 0: in Connecting state.
    [41] Exception: {Opc.Ua.ServiceResultException} BadNotConnected
    Exception: {Opc.Ua.ServiceResultException} Error establishing a connection: BadNotConnected
    SDK trace: GetEndpoints Completed. RequestHandle=1, PendingRequestCount=0, StatusCode=-2147483648
    Events starting with activity ID in [] may not necessarily be related to the current action.
    ErrorId_{045406CD-8EEA-4F21-B3D6-DC9DB5A34E58}: OpcLabs.UAEngine=1
    ((39, 1), Opc.Ua.TraceEventArgs)
    ((41, 0), System.Runtime.ExceptionServices.FirstChanceExceptionEventArgs)
    ((39, 1), System.Runtime.ExceptionServices.FirstChanceExceptionEventArgs)
    c3c0e69e-bf8f-4bfa-8e93-816783737e55: 39
    8970fe52-aaa4-40f7-9a6e-74cdcee56724: DiscoveryClient.GetEndpoints
    Error Code: 1
    InnerException: OpcLabs.EasyOpc.UA.UAServiceException: OPC UA service result - Error establishing a connection: BadNotConnected.
    ErrorId_{045406CD-8EEA-4F21-B3D6-DC9DB5A34E58}: Opc.UA.ServiceResult=0x808A0000
    Help Link:
    Internal Code: 2156527616
    Message: OPC UA service result - Error establishing a connection: BadNotConnected.
    Service Result: BadNotConnected
    Additional Info:
    Description: Error establishing a connection: BadNotConnected
    Inner Result: BadNotConnected
    Additional Info:
    >>> BadNotConnected
    --- at Opc.Ua.Bindings.ChannelAsyncOperation`1.End(Int32 timeout, Boolean throwOnError)
    --- at Opc.Ua.Bindings.UaSCUaBinaryClientChannel.OnConnectOnDemandComplete(Object state)
    Description: BadNotConnected
    Inner Result:
    Message: BadNotConnected.
    Qualified Symbolic ID:
    Expanded Text:
    Is Null: True
    Is Standard: True
    Name:
    Namespace Index: 0
    Namespace URI:
    Namespace URI String:
    Standard Name:
    Status Code: BadNotConnected
    Code Bits: 32906
    Code Bits Symbol: BadNotConnected
    Condition: 138
    Description: The variable should receive its value from another variable, but has never been configured to do so.
    Flag Bits: 0
    Has Data Value Info: False
    Info Type: NotUsed
    Internal Value: 2156527616
    Is Bad: True
    Is Good: False
    Is Uncertain: False
    Limit Info: None
    Overflow: False
    Semantics Changed: False
    Severity: BadOrFailure
    Status Info: Error
    Structure Changed: False
    Text: {BadNotConnected}. BadNotConnected.
    Message: Error establishing a connection: BadNotConnected.
    Expanded Text:
    Is Null: True
    Is Standard: True
    Name:
    Namespace Index: 0
    Namespace URI:
    Standard Name:
    Code Bits: 32906
    Condition: 138
    Flag Bits: 0
    Info Type: NotUsed
    Is Bad: True
    Is Good: False
    Is Uncertain: False
    Limit Info: None
    Overflow: False
    Status Info: Error
    Text: Error establishing a connection: BadNotConnected.
    Service Target Site: T End(Int32, Boolean)
    DeclaringType: Opc.Ua.Bindings.ChannelAsyncOperation`1[T]
    Module: Opc.Ua.Core.dll
    Assembly: Opc.Ua.Core, Version=1.4.371.0, Culture=neutral, PublicKeyToken=bfa7a73c5cf4b6e8
    CustomAttributes:
    MDStreamVersion: 131072
    MetadataToken: 1
    ModuleVersionId: e90038f5-d9d5-4c0c-b2e7-eda655301ec4
    ScopeName: Opc.Ua.Core.dll
    Source: Opc.Ua.Core
    Stack Trace:
    at Opc.Ua.Bindings.UaSCUaBinaryClientChannel.EndSendRequest(IAsyncResult result)
    at Opc.Ua.Bindings.UaSCUaBinaryTransportChannel.EndSendRequest(IAsyncResult result)
    at Opc.Ua.Bindings.UaSCUaBinaryTransportChannel.SendRequest(IServiceRequest request)
    at Opc.Ua.DiscoveryClient.GetEndpoints(RequestHeader requestHeader, String endpointUrl, StringCollection localeIds, StringCollection profileUris, EndpointDescriptionCollection& endpoints)
    at OpcLabs.EasyOpc.UA.Toolkit.Sdk.ToolkitDiscoveryClient.OpcLabs.EasyOpc.UA.Toolkit.Client.ISdkDiscoveryClient.GetEndpoints(String endpointUrl, StringCollection sdkProfileUris)
    at OpcLabs.EasyOpc.UA.Toolkit.Sdk.ClientUtils.<>c__DisplayClass60_1.<SelectEndpointInternal>b__3()
    TargetSite:
    Message:
    Source:
    Stack Trace:
    == Activity Trace ==
    TargetSite:
    Source:
    TargetSite:
    Time to create page: 0.186 seconds
