It seems writing a DateTime with with EasyDAClient.WriteItem() is not supported
28 Nov 2023 16:32 #12418 by ScottEwine
That was it, working now! Thank you very much!
28 Nov 2023 16:14 #12417 by support
The DateTime you pass into this method must be in UTC: Use ToUniversalTime or SpecifyKind method as needed.
The error message is not good enough, and we will fix in the next version.
The following user(s) said Thank You: ScottEwine
28 Nov 2023 13:13 #12414 by ScottEwine
I am trying to write a value to my historian with a DateTime (which I guess makes it HDA, not DA) and it gives an obscure error.
Message: "timestamp"
I guess this means writing a date/time with the value is not supported, as that would be HDA? Do you have a tool that supports HDA?
static DAVtq WriteOPCDAVtq(string MachineName, string ServerName, string ItemID, object value, DateTime dateTime)
EasyDAClient easyDAClient1 = new EasyDAClient();
try
easyDAClient1.WriteItem(MachineName, ServerName, ItemID, value, dateTime, 192);
catch (Exception Ex)
Console.WriteLine(Ex.Message);
LogError(Ex);
return null;
