Strange disconnection from OPC-UA server with exception
28 Nov 2023 15:48 #12415 by support
The error means that the server is not maintaining the subscription as it should (it failed to keep sending Publish requests often enough). You need to resolve the problem on the server.
Less likely, it can mean network problem.
Even less likely, a bug on the client side.
If you have reasons to suspect the "less likely" cases, it would be necessary to collect the network communication (Wireshark) and analyze it.
28 Nov 2023 09:45 #12412 by Scattolaro
I'm using the Easy OPC-Ua client for .Net version 5.71.273 and after a couple of hours that work properly(correct reading in subscribe or readmultiple) I get the following exception:
Exception: OpcLabs.EasyOpc.UA.Engine.UAEngineException: The OPC-UA subscription ID 2 publishing has halted on the client session to endpoint URL "opc.tcp://192.168.10.20:4840" for approximate current duration of 12642 milliseconds. The current keep-alive count is 10, the current publishing interval is 500 milliseconds, and the probationary period was 5000 milliseconds.+ The client method called (or event/callback invoked) was 'DataChangeNotification'.(The OPC-UA subscription ID 2 publishing has halted on the client session to endpoint URL "opc.tcp://192.168.10.20:4840" for approximate current duration of 12642 milliseconds. The current keep-alive count is 10, the current publishing interval is 500 milliseconds, and the probationary period was 5000 milliseconds.+ The client method called (or event/callback invoked) was 'DataChangeNotification'.) Trace:
What happen? Can you help me? What can I do to overcome the exception?
Thaks,
