Exception when browsing an OPC UA Server
09 Nov 2023 16:12 #12344 by micham
Next time I will start a new thread. I thought it is related...
Two questions regarding solution 2) below,
1) Do you mean this section?
EasyUAApplication.Instance.ApplicationParameters.ApplicationManifest.ApplicationName =
"QuickOPC - VBNet example application"
If we do it, what will be displayed in the Administer OPC UA Application -> Application Certificate -> Subject URL name? See below.
2) Will it show the application name that we set in our code?
    09 Nov 2023 13:38 - 09 Nov 2023 13:41 #12341 by support
    next time, please create a new forum thread, for reporting new issues. You can always link to some other thread if there is a relationship.
    It is difficult to judge, because the pictures you have attached have degraded resolution. But after some enlarging, and some guesswork, I think that I can see that the reason (see picture):
    You have probably updated your software, and also updated its version number. The default QuickOPC behavior is that it constructs the OPC UA Application URI based on various pieces of information, including the version number. But, the Application URI must match the one in the application certificate - and in this case, it does not (the certificate has ....108.0 in it, but the software itself is ....109.0).
    Some applications benefit from this behavior (because it allows multiple versions of the application coexist on the same computer), while others do not (because they want the application to effectively remain "THE SAME" application after a version update).
    You can either:
    1) Regenerate the certificate (the "Create/recreate own certificate"); in turn, you will have to re-establish the trust on the server side (so that the server trusts the new client certificate). And, repeat this process every time the application version changes.
    OR
    2) At the beginning of your application, place a piece of code that will configure a more "fixed" application URI, such as that it does not change with version number changes [this does not resolve the very current instance of the problem; but it just addresses the same thing for all future deployments]. See: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...%20Application%20Manifest.html . In short, you need to set some URI string into the EasyUAApplication.Instance.ApplicationParameters.ApplicationManifest.ApplicationUriString property.
  • Last edit: 09 Nov 2023 13:41 by support.
    09 Nov 2023 11:32 #12340 by micham
    Operating system is Windows Server 2016.
    Today we tried connecting and reading OPC items and got an exception. See the attached files.
    Any idea what is the problem? UA Expert works fine.
    11 Oct 2023 06:46 #12288 by support
    I do not want to side-track you too much from the main issue (which is establishing the communication between the client and the server, and all the certificate-related stuff), but I have some additional questions from the developer regarding the crash you got while browsing (after existing the OPC UA Application Administration dialog). If you can answer at least part of it, it would be nice.
    1. Can you reproduce it multiple times, or was it "one-time" occurrence?
    2. Did it happen on Windows 10, or Windows 11?
    3. Is there an entry in Windows Application log at the time of crash, and if so, can yo please send its full text? Or, if the crash happens again, please select all text in the crash dialog, copy it and send over (i.e. not just the screenshot - because it contains just part of the call stack, not the whole stack)
    Many thanks
    10 Oct 2023 15:54 #12286 by support
    Believe me or not, we are making progress. This error was expected. You now have a new client-side certificate, so the server needs to be configured to accept it.
    After you/your customer does so, you should be OK.
    10 Oct 2023 15:50 #12285 by micham
    Hi Thank you for your answers.
    See my response below. I still get an exception.
    Exceptions
    OpcLabs.EasyOpc.UA.Engine.UAEngineException: UA SDK error (Opc.UA.ServiceResult=0x80130000) in 'static Session.Create'. OPC UA service result - {BadSecurityChecksFailed}. Error establishing a connection: Error received from remote host:.
    + Connection attempt #1; last connected at 01-01-01 00:00:00 (local); unconnected for 00:00:00.
    + The endpoint URL string used was "opc.tcp://GTCHVE3SA01:4840".
    + The client method called (or event/callback invoked) was 'BrowseMultiple[1]'. ---> OpcLabs.EasyOpc.UA.UAServiceException: OPC UA service result - {BadSecurityChecksFailed}. Error establishing a connection: Error received from remote host:.
    --> {BadSecurityChecksFailed}. Error received from remote host:. Error establishing a connection: Error received from remote host:
    Activity Trace:
    Following (25) events were gathered during the action on activity ID [24], in the order of first occurrence:
    SDK trace: Imported the PFX private key for [E4497FB07A132B655DEEABCC37B2F547CA162E4A].
    SDK trace: An unexpected certificate was used in the certificate chain. [CN=GTCHVE3SA01 Root CA] [11A710E518FAF255C41A884EF3EEEE2E2607C9AE]
    2*Exception: {Opc.Ua.ServiceResultException} Certificate chain validation incomplete.
    SDK trace: Certificate Validation failed. Reason=BadCertificateChainIncomplete. [CN=GTCHVE3SA01 OPCUA Server] [D4E1EEF087B0B7D54DC8887C97276DFD72B35C7C]
    SDK trace: -- BadCertificateUntrusted 'Certificate is not trusted.'
    SDK trace: -- BadCertificateUntrusted 'Certificate Issuer is not trusted.'
    SDK trace: Validation errors suppressed: [CN=GTCHVE3SA01 OPCUA Server] [D4E1EEF087B0B7D54DC8887C97276DFD72B35C7C]
    SDK trace: CreateSession Called. RequestHandle=1, PendingRequestCount=1
    SDK trace: ChannelId 0: in Connecting state.
    [7] SDK trace: ChannelId 0: SendHelloMessage()
    [7] SDK trace: ChannelId 0: ProcessAcknowledgeMessage()
    [7] SDK trace: ChannelId 0: in Opening state.
    [7] SDK trace: ChannelId 0: Token #0 created. CreatedAt=15:30:44.544. Lifetime=3600000.
    [7] SDK trace: ChannelId 0: ProcessErrorMessage(BadSecurityChecksFailed 'Error received from remote host: ')
    [31] Exception: {Opc.Ua.ServiceResultException} Error received from remote host:
    4*Exception: {Opc.Ua.ServiceResultException} Error establishing a connection: Error received from remote host:
    SDK trace: CreateSession Completed. RequestHandle=1, PendingRequestCount=0, StatusCode=-2147483648
    [34] SDK trace: ChannelId 0: Force reconnect reason=BadConnectionClosed 'Remote side closed connection'
    [34] SDK trace: ChannelId 0: in Closed state.
    [34] SDK trace: ChannelId 0: CLIENTCHANNEL SOCKET CLOSED: 030EEF05
    Exception: {System.AggregateException} One or more errors occurred.
    Events starting with activity ID in [] may not necessarily be related to the current action.
    ErrorId_{045406CD-8EEA-4F21-B3D6-DC9DB5A34E58}: OpcLabs.UAEngine=1
    ((24, 1), Opc.Ua.TraceEventArgs)
    ((24, 1), System.Runtime.ExceptionServices.FirstChanceExceptionEventArgs)
    ((7, 0), Opc.Ua.TraceEventArgs)
    ((31, 0), System.Runtime.ExceptionServices.FirstChanceExceptionEventArgs)
    ((34, 0), Opc.Ua.TraceEventArgs)
    c3c0e69e-bf8f-4bfa-8e93-816783737e55: 24
    8970fe52-aaa4-40f7-9a6e-74cdcee56724: static Session.Create
    Error Code: 1
    ErrorId_{045406CD-8EEA-4F21-B3D6-DC9DB5A34E58}: Opc.UA.ServiceResult=0x80130000
    Help Link:
    Internal Code: 2148728832
    Message:
    Service Result: BadSecurityChecksFailed
    Additional Info:
    Description: Error establishing a connection: Error received from remote host:
    Inner Result: BadSecurityChecksFailed
    Additional Info:
    --- at Opc.Ua.Bindings.ChannelAsyncOperation`1.End(Int32 timeout, Boolean throwOnError)
    --- at Opc.Ua.Bindings.UaSCUaBinaryClientChannel.OnConnectOnDemandComplete(Object state)
    Description: Error received from remote host:
    Inner Result:
    Message: Error received from remote host:.
    Qualified Symbolic ID:
    Expanded Text:
    Is Null: True
    Is Standard: True
    Name:
    Namespace Index: 0
    Namespace URI:
    Namespace URI String:
    Standard Name:
    Status Code: BadSecurityChecksFailed
    Code Bits: 32787
    Code Bits Symbol: BadSecurityChecksFailed
    Condition: 19
    Description: An error occurred verifying security.
    Flag Bits: 0
    Has Data Value Info: False
    Info Type: NotUsed
    Internal Value: 2148728832
    Is Bad: True
    Is Good: False
    Is Uncertain: False
    Limit Info: None
    Overflow: False
    Semantics Changed: False
    Severity: BadOrFailure
    Status Info: Error
    Structure Changed: False
    Text: {BadSecurityChecksFailed}. Error received from remote host:.
    Message: Error establishing a connection: Error received from remote host:.
    Expanded Text:
    Is Null: True
    Is Standard: True
    Name:
    Namespace Index: 0
    Namespace URI:
    Standard Name:
    Code Bits: 32787
    Condition: 19
    Flag Bits: 0
    Info Type: NotUsed
    Is Bad: True
    Is Good: False
    Is Uncertain: False
    Limit Info: None
    Overflow: False
    Status Info: Error
    Text:
    Service Target Site: T End(Int32, Boolean)
    DeclaringType: Opc.Ua.Bindings.ChannelAsyncOperation`1[T]
    Module: Opc.Ua.Core.dll
    Assembly: Opc.Ua.Core, Version=1.4.371.0, Culture=neutral, PublicKeyToken=bfa7a73c5cf4b6e8
    CustomAttributes:
    MDStreamVersion: 131072
    MetadataToken: 1
    ModuleVersionId: e90038f5-d9d5-4c0c-b2e7-eda655301ec4
    ScopeName: Opc.Ua.Core.dll
    Source: Opc.Ua.Core
    Stack Trace:
    at Opc.Ua.Bindings.UaSCUaBinaryClientChannel.EndSendRequest(IAsyncResult result)
    at Opc.Ua.Bindings.UaSCUaBinaryTransportChannel.EndSendRequest(IAsyncResult result)
    at Opc.Ua.Bindings.UaSCUaBinaryTransportChannel.SendRequest(IServiceRequest request)
    at Opc.Ua.SessionClient.CreateSession(RequestHeader requestHeader, ApplicationDescription clientDescription, String serverUri, String endpointUrl, String sessionName, Byte[] clientNonce, Byte[] clientCertificate, Double requestedSessionTimeout, UInt32 maxResponseMessageSize, NodeId& sessionId, NodeId& authenticationToken, Double& revisedSessionTimeout, Byte[]& serverNonce, Byte[]& serverCertificate, EndpointDescriptionCollection& serverEndpoints, SignedSoftwareCertificateCollection& serverSoftwareCertificates, SignatureData& serverSignature, UInt32& maxRequestMessageSize)
    at Opc.Ua.Client.Session.CreateSession(RequestHeader requestHeader, ApplicationDescription clientDescription, String serverUri, String endpointUrl, String sessionName, Byte[] clientNonce, Byte[] clientCertificate, Double requestedSessionTimeout, UInt32 maxResponseMessageSize, NodeId& sessionId, NodeId& authenticationToken, Double& revisedSessionTimeout, Byte[]& serverNonce, Byte[]& serverCertificate, EndpointDescriptionCollection& serverEndpoints, SignedSoftwareCertificateCollection& serverSoftwareCertificates, SignatureData& serverSignature, UInt32& maxRequestMessageSize)
    at OpcLabs.EasyOpc.UA.Sdk.Shims.SessionShim.CreateSession(RequestHeader requestHeader, ApplicationDescription clientDescription, String serverUri, String endpointUrl, String sessionName, Byte[] clientNonce, Byte[] clientCertificate, Double millisecondsRequestedSessionTimeout, UInt32 maxResponseMessageSize, NodeId& sessionId, NodeId& authenticationToken, Double& millisecondsRevisedSessionTimeout, Byte[]& serverNonce, Byte[]& serverCertificate, EndpointDescriptionCollection& serverEndpoints, SignedSoftwareCertificateCollection& serverSoftwareCertificates, SignatureData& serverSignature, UInt32& maxRequestMessageSize)
    at OpcLabs.EasyOpc.UA.Sdk.Shims.SessionShim.Open2(String sessionName, UInt32 sessionTimeout, IUserIdentity identity, IList`1 preferredLocales, Boolean checkDomain)
    at OpcLabs.EasyOpc.UA.Sdk.Shims.SessionShim.<Create>d__4.MoveNext()
    --- End of stack trace from previous location where exception was thrown ---
    at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
    at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
    at OpcLabs.EasyOpc.UA.Toolkit.Sdk.ToolkitSession.<Create>d__2.MoveNext()
    TargetSite:
    Message:
    Source:
    Stack Trace:
    == Activity Trace ==
    TargetSite:
    Source:
    TargetSite:
    10 Oct 2023 11:50 #12284 by support
    Hello, and thank you.
    Notes:
    - No wonder "Refresh Trust Lists" does not work; I have not instructed you to do that
    - The crash after exiting the dialog: This is clearly our problem, I will pass it onto the developer.
    But, from the screenshots I have enough information to proceed forward.
    Please do the following:
    1. Invoke the OPC UA Application Administration dialog again.
    2. Switch to the "Application Certificate" tab.
    3. Press "Create/recreate own certificate". If you get Yes/No confirmation about certificate validation, answer Yes.
    4. Take a screenshot of the "Application Certificate" tab after the previous step.
    5. Exit the OPC UA Application Administration dialog.
    6. Retest. If you run into problems, send me the information about the behavior, AND the screenshot from Step 4.
    10 Oct 2023 10:57 #12282 by micham
    See my answers below.
    1. See the screen captures below.
    2. After clicking on "Refresh Trust list, we got this error:
    The exception details are below:
    Exception Details: Error Refreshing OPC UA Application Trust Lists
    Type: OpcLabs.BaseLib.Portable.CustomException
    Data: ErrorId_{045406CD-8EEA-4F21-B3D6-DC9DB5A34E58}: OpcLabs.{82C2F70B}
    InnerException: OpcLabs.BaseLib.Licensing.LicensingException: License for specialized client 'EasyUAGlobalDiscoveryClient' is not granted. Obtain and install proper license to resolve this error.
    Data: ErrorId_{045406CD-8EEA-4F21-B3D6-DC9DB5A34E58}: {7479D92B}
    HResult: -2146232063 (0x80131901)
    Instance:
    System.Reflection.TargetInvocationException: Property accessor 'Instance' on object 'OpcLabs.BaseLib.Licensing.LicensingException' threw the following exception:'The member with the specified name "instance" has not been found.' ---> OpcLabs.BaseLib.MemberNotFoundException: The member with the specified name "instance" has not been found.
    at OpcLabs.BaseLib.Extensions.Internal.ObjectExtension.GetFieldValue(Object obj, String name)
    at OpcLabs.BaseLib.Licensing.LicensingException.get_Instance()
    at System.ComponentModel.ReflectPropertyDescriptor.GetValue(Object component)
    at OpcLabs.BaseLib.Forms.Common.ReadOnlyPropertyDescriptor.OriginalPropertyDescriptorGetValue(Object component)
    LicensedType: OpcLabs.EasyOpc.UA.Gds.EasyUAGlobalDiscoveryClient
    Message: License for specialized client 'EasyUAGlobalDiscoveryClient' is not granted. Obtain and install proper license to resolve this error.
    Source:
    TargetSite:
    Message: Error finding OPC UA applications for URI "uri:GTCPMP1:EBOOPCClientCFG:1.0.108.0" in GDS "opc.tcp://localhost:58810/GlobalDiscoveryServer".
    Source:
    TargetSite:
    After exitng the "Administer OPC UA" window and trying to browse, we got the error below.
    3. I am not sure I understand what you mean by "Are you able to connect when you answer "Yes" to the notification?" . The exception is when we try to browse for OPC UA items.
    4. I tried it. See the screen captures below.
    5. When we tried browsing we got the same error as before.
    10 Oct 2023 09:23 #12281 by support
    You have not answered any of my questions in my last post. I need those answers.
    Here are the questions again:
    Questions:
    1. Please also include screenshot of the "Application Certificate" tab of the dialog.
    2. Please also include screenshot of the "Application Manifest" tab of the dialog.
    3. Are you able to connect when you answer "Yes" to the notification? If not, is the exception in "Browse for OPC-UA Data" different between the Yes and No responses - and what are the 2 exceptions in these cases?
    4. On the "Trusted Certificates" tab, select the second row (the one with "GTCHVE3SA01 OPCUA Server". Then, click the "Trusted" item under "Trust Status" in the action pane on the right side. The "Trust Status" column for that certificate should change to "Trusted, Issuer". Exit the dialog, exit the application, and start it again. Is the problem resolved now? If not, are you getting the same symptoms, or is the behavior now different? If it is different, please describe the new behavior.
    10 Oct 2023 09:14 #12280 by micham
    Now our OPC Client is based on Quick OPC V2023.1.
    OPC UA Expert can connect with the remote OPC server with no errors. See below.
    Our OPC UA Client fails to connect to the same server. See the error below.
    Time to create page: 0.351 seconds
