License issue
20 Jun 2023 09:05 #11823 by eshaq.quadri
Replied by eshaq.quadri on topic License issue
Thanks it worked out when i tried below point1
19 Jun 2023 13:27 #11821 by support
Replied by support on topic License issue
I think you misunderstood question #4. The OPC UA application certificates have absolutely nothing to do with QuickOPC licensing. I will be assuming that you are not supplying your own OPC UA application certificate then; correct me if this is not the case.
It is clear from the error message that the user account that runs the application is missing some permissions to some all all directories under C:\ProgramData\OPC Foundation\CertificateStores\ . Please try this:
1. Inspect all sub-directories C:\ProgramData\OPC Foundation\CertificateStores\ (recursively), and remove any files that start with "QC conel".
2. Using the Windows security permissions settings, make sure that the user account that runs the application can read/write&modify all sub-directories of C:\ProgramData\OPC Foundation\CertificateStores\ (recursively).
3. Run your program again.
19 Jun 2023 06:19 #11819 by eshaq.quadri
quick OPC 2022.1
.net framework
Its Windows console app
We are attaching the license under quick opc provided when we purchased the OPC
we are running under admin priveleges
18 Jun 2023 18:42 #11817 by support
2. Are you targeting .NET Framework, or .NET Core/.NET 6+?
3. What type of project are you building? (such as Windows desktop app, Windows console app, Web service, Windows service, ...)
4. Are you trying to supply your own OPC UA application certificate, or do you rely on QuickOPC to create it for you (the default behavior)?
5. Are you running the application under normal user account, or an account with admin privileges?
18 Jun 2023 14:30 #11816 by eshaq.quadri
License issue was created by eshaq.quadri
Dear OPC support,
we are encountering below error when fetching tags. Please guide on it.
An OPC-UA operation failure with error ID 'OpcLabs.UAEngine=1' occurred, originating from 'Opc.Ua.Core' and with depth of 2. The inner exception, of type "OpcLabs.EasyOpc.UA.Engine.UAEngineException", contains details about the problem. at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.Read(IEasyUAClient client, UAReadArguments readArguments)
at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.Read(IEasyUAClient client, UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor)
at QC_conel.Program.Read_Multiple(Boolean isUpdateDb) in \\sharemedia\Source Codes\APIs\Maximo Integration\PLCData\QC conel\Program.cs:line 79
UA SDK error (Opc.UA.ServiceResult=0x801A0000) in 'ApplicationInstance.CheckApplicationInstanceCertificate'. OPC UA service result - {BadCertificateUntrusted}. The certificate is not trusted.
+ The error occurred while creating or checking the (client) application instance certificate. Check event log entries for errors and warnings.
+ Suggestion: Check the trusted peers certificate store for the presence of the application instance certificate. This error can happen if the instance certificate is in the application instance store, but not in the trusted peers certificate store.
+ The certificate generator path was "E:\Scheduled Tasks\Maximo Integration\QCs_PLC - Copy\Opc.Ua.CertificateGenerator.exe".
+ This is an engine-level error. It is unrelated to any specific target server connection.
+ Connection attempt #1; last connected at 1/1/0001 12:00:00 AM (local); unconnected for 00:00:00.2190000.
+ The client method called (or event/callback invoked) was 'ReadMultiple[1]'. == Activity Trace ==
Following (8) events were gathered during the action on activity ID [11], in the order of first occurrence:
SDK trace: Checking application instance certificate.
SDK trace: Checking application instance certificate. CN=QC conel, DC=SRV-Tabadul
2*Exception: {Opc.Ua.ServiceResultException} Self Signed Certificate is not trusted. IssuerName: CN=QC conel, DC=SRV-Tabadul
SDK trace: Certificate 'CN=QC conel, DC=SRV-Tabadul' rejected. Reason=BadCertificateUntrusted
SDK trace: Writing rejected certificate to directory: [Directory]%CommonApplicationData%\OPC Foundation\CertificateStores\RejectedCertificates
Exception: {System.UnauthorizedAccessException} Access to the path 'C:\ProgramData\OPC Foundation\CertificateStores\RejectedCertificates\private\QC conel [60641CF8AA864A0B665E3C6F8E9233EECC6730AC].pfx' is denied.
SDK trace: Could not write certificate to directory: [Directory]%CommonApplicationData%\OPC Foundation\CertificateStores\RejectedCertificates UnauthorizedAccessException 'Access to the path 'C:\ProgramData\OPC Foundation\CertificateStores\RejectedCertificates\private\QC conel [60641CF8AA864A0B665E3C6F8E9233EECC6730AC].pfx' is denied.'
