- Thank you received: 2
OpcLabs.QuickOpc 5.70.1053 - .NET Framework 8 - Problem
C:\Users\Admin>C:\Windows\Microsoft.NET\Framework64\v4.0.30319\InstallUtil.exe "C:\Users\Admin\source\repos\QuickOPCTest\bin\x64\Debug\QuickOPCTest.exe"
Microsoft (R) .NET Framework Installation utility Version 4.8.4084.0
Copyright (C) Microsoft Corporation. All rights reserved.
Running a transacted installation.
Beginning the Install phase of the installation.
See the contents of the log file for the C:\Users\Admin\source\repos\QuickOPCTest\bin\x64\Debug\QuickOPCTest.exe assembly's progress.
The file is located at C:\Users\Admin\source\repos\QuickOPCTest\bin\x64\Debug\QuickOPCTest.InstallLog.
Installing assembly 'C:\Users\Admin\source\repos\QuickOPCTest\bin\x64\Debug\QuickOPCTest.exe'.
Affected parameters are:
logtoconsole =
assemblypath = C:\Users\Admin\source\repos\QuickOPCTest\bin\x64\Debug\QuickOPCTest.exe
logfile = C:\Users\Admin\source\repos\QuickOPCTest\bin\x64\Debug\QuickOPCTest.InstallLog
Unable to create an instance of the QuickOPCTest.Installer1 installer type.
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation.
The inner exception System.TypeInitializationException was thrown with the following error message: The type initializer for 'QuickOPCTest.Service1' threw an exception..
The inner exception System.TypeInitializationException was thrown with the following error message: The type initializer for 'OpcLabs.EasyOpc.DataAccess.EasyDAClient' threw an exception..
The inner exception System.IO.FileNotFoundException was thrown with the following error message: Could not load file or assembly 'System.Runtime.CompilerServices.Unsafe, Version=4.0.4.1, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The system cannot find the file specified..
I am able to run the project inside VS 2022 and run the standalone .exe but when I try to install this project as a Windows Service using 'C:\Windows\Microsoft.NET\Framework64\v4.0.30319\InstallUtil.exe', I get the following error:
The transacted install has completed.
The installation failed, and the rollback has been performed.
Unhandled Exception: System.TypeInitializationException: The type initializer for 'Comm.Server.CommunicationService' threw an exception. ---> System.TypeInitializationException: The type initializer for 'OpcLabs.EasyOpc.DataAccess.EasyDAClient' threw an exception. ---> System.IO.FileNotFoundException: Could not load file or assembly 'System.Runtime.CompilerServices.Unsafe, Version=4.0.4.1, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' or one of its dependencies. The system cannot find the file specified.
at System.MemoryExtensions.AsSpan(String text, Int32 start, Int32 length)
at Microsoft.Extensions.FileProviders.Physical.Internal.PathUtils.PathNavigatesAboveRoot(String path)
at Microsoft.Extensions.FileProviders.Physical.PhysicalFilesWatcher.CreateFileChangeToken(String filter)
at Microsoft.Extensions.Primitives.ChangeToken.ChangeTokenRegistration`1..ctor(Func`1 changeTokenProducer, Action`1 changeTokenConsumer, TState state)
at Microsoft.Extensions.Primitives.ChangeToken.OnChange(Func`1 changeTokenProducer, Action changeTokenConsumer)
at Microsoft.Extensions.Configuration.FileConfigurationProvider..ctor(FileConfigurationSource source)
at Microsoft.Extensions.Configuration.Json.JsonConfigurationSource.Build(IConfigurationBuilder builder)
at Microsoft.Extensions.Configuration.ConfigurationBuilder.Build()
at Microsoft.Extensions.Hosting.HostBuilder.BuildAppConfiguration()
at Microsoft.Extensions.Hosting.HostBuilder.Build()
at System.Lazy`1.CreateValue()
at System.Lazy`1.LazyInitValue()
at OpcLabs.BaseLib.Extensions.Hosting.StaticHost.GetConfiguration()
at OpcLabs.EasyOpc.DataAccess.EasyDAClient..cctor()
at OpcLabs.EasyOpc.DataAccess.EasyDAClient..ctor()
at Comm.Server.CommunicationService..cctor()
at Comm.Server.CommunicationService.Dispose(Boolean disposing)
at System.ComponentModel.Component.Finalize()
This project uses many other NuGet packages which ends up generating the following binding redirects:
<assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
<dependentAssembly>
<assemblyIdentity name="System.Memory" publicKeyToken="cc7b13ffcd2ddd51" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-4.0.1.1" newVersion="4.0.1.1" />
</dependentAssembly>
<dependentAssembly>
<assemblyIdentity name="System.Threading.Tasks.Extensions" publicKeyToken="cc7b13ffcd2ddd51" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-4.2.0.1" newVersion="4.2.0.1" />
<dependentAssembly>
<assemblyIdentity name="System.Buffers" publicKeyToken="cc7b13ffcd2ddd51" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-4.0.3.0" newVersion="4.0.3.0" />
<dependentAssembly>
<assemblyIdentity name="System.Runtime.CompilerServices.Unsafe" publicKeyToken="b03f5f7f11d50a3a" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-6.0.0.0" newVersion="6.0.0.0" />
<dependentAssembly>
<assemblyIdentity name="Microsoft.Extensions.Primitives" publicKeyToken="adb9793829ddae60" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="System.Collections.Immutable" publicKeyToken="b03f5f7f11d50a3a" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-1.2.5.0" newVersion="1.2.5.0" />
<dependentAssembly>
<assemblyIdentity name="System.Text.Encodings.Web" publicKeyToken="cc7b13ffcd2ddd51" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="Microsoft.Extensions.FileProviders.Abstractions" publicKeyToken="adb9793829ddae60" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="Microsoft.Extensions.DependencyInjection.Abstractions" publicKeyToken="adb9793829ddae60" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="Microsoft.Extensions.Options" publicKeyToken="adb9793829ddae60" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="System.IO.Pipelines" publicKeyToken="cc7b13ffcd2ddd51" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-6.0.0.3" newVersion="6.0.0.3" />
<dependentAssembly>
<assemblyIdentity name="Microsoft.Extensions.Configuration.Abstractions" publicKeyToken="adb9793829ddae60" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="System.Security.Cryptography.Cng" publicKeyToken="b03f5f7f11d50a3a" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-4.3.1.1" newVersion="4.3.1.1" />
<dependentAssembly>
<assemblyIdentity name="Microsoft.Extensions.Logging.Abstractions" publicKeyToken="adb9793829ddae60" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="System.Numerics.Vectors" publicKeyToken="b03f5f7f11d50a3a" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-4.1.4.0" newVersion="4.1.4.0" />
<dependentAssembly>
<assemblyIdentity name="Microsoft.Extensions.Configuration" publicKeyToken="adb9793829ddae60" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="Microsoft.Extensions.Configuration.Binder" publicKeyToken="adb9793829ddae60" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="Microsoft.AspNetCore.Server.Kestrel.Core" publicKeyToken="adb9793829ddae60" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-2.1.25.0" newVersion="2.1.25.0" />
<dependentAssembly>
<assemblyIdentity name="Microsoft.Extensions.DependencyInjection" publicKeyToken="adb9793829ddae60" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="System.Diagnostics.DiagnosticSource" publicKeyToken="cc7b13ffcd2ddd51" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="Microsoft.Extensions.Logging" publicKeyToken="adb9793829ddae60" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="Microsoft.Extensions.Hosting.Abstractions" publicKeyToken="adb9793829ddae60" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="Microsoft.Extensions.Configuration.EnvironmentVariables" publicKeyToken="adb9793829ddae60" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="Microsoft.Extensions.Configuration.FileExtensions" publicKeyToken="adb9793829ddae60" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="Microsoft.AspNetCore.Http" publicKeyToken="adb9793829ddae60" culture="neutral" />
<bindingRedirect oldVersion="0.0.0.0-2.1.22.0" newVersion="2.1.22.0" />
<dependentAssembly>
<assemblyIdentity name="Microsoft.Extensions.FileProviders.Physical" publicKeyToken="adb9793829ddae60" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="Microsoft.Bcl.AsyncInterfaces" publicKeyToken="cc7b13ffcd2ddd51" culture="neutral" />
<dependentAssembly>
<assemblyIdentity name="System.Text.Json" publicKeyToken="cc7b13ffcd2ddd51" culture="neutral" />
</assemblyBinding>
I have tried forcing the redirect for System.Runtime.CompilerServices.Unsafe towards 4.0.4.1 but that makes no difference at all.
Ideas? Suggestions?
