EasyDAItemChangedEventHandlers
24 Mar 2023 18:34 #11639 by support
Also,
for a list of changes in each version, see kb.opclabs.com/Versions (clicking on the links under "What's New" leads to pages with more details).
regards
The following user(s) said Thank You: hkadhim
24 Mar 2023 18:32 #11638 by support
Events that supplied multiple changes at once were removed, because in the end they have not provided the performance improvement they were supposed to have. Simply use the events that are generated once per each change.
It is also possible that the name of the type providing item change event arguments have changed - 5.23 is very old version (might be approaching 10 years). 5.59 isn't quite up-to-date either.
Here is the current example code:, you can learn the type name from it:
opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...%20to%20a%20single%20item.html
' Hooking up events and receiving OPC item changes. Imports System.Threading Imports OpcLabs.EasyOpc.DataAccess Imports OpcLabs.EasyOpc.DataAccess.OperationModel Namespace DocExamples.DataAccess._EasyDAClient Partial Friend Class SubscribeItem Shared Sub Main1() Using client = New EasyDAClient() Dim eventHandler = New EasyDAItemChangedEventHandler(AddressOf client_ItemChanged) AddHandler client.ItemChanged, eventHandler Console.WriteLine("Subscribing item...") client.SubscribeItem("", "OPCLabs.KitServer.2", "Demo.Ramp", 200) Thread.Sleep(30 * 1000) client.UnsubscribeAllItems() RemoveHandler client.ItemChanged, eventHandler End Using End Sub Private Shared Sub client_ItemChanged(sender As Object, e As EasyDAItemChangedEventArgs) If e.Succeeded Then Console.WriteLine(e.Vtq) Else Console.WriteLine("*** Failure: {0}", e.ErrorMessageBrief) End If End Sub End Class End Namespace
I hope this helps
24 Mar 2023 18:22 #11637 by hkadhim
I used to have a working function in version 5.23 and then I upgraded to the latest version 5.59 and it doesn't work anymore, ItemChanged & MultipleItemsChanged functions, the DataAccess.EasyDAMultipleItemsChangedEventArgs and DataAccess.EasyDAItemChangedEventHandlers do not seem to exist anymore:
Public Sub ItemChanged(ByVal sender As Object, ByVal e As DataAccess.EasyDAItemChangedEventHandlers) Handles m_opcClient.ItemChanged Dim Tag As HQTag = CType(e.State, HQTag) If e.Exception IsNot Nothing Then Tag.ServerError = e.Exception.GetHashCode Else Tag.Value = e.Vtq.Value End If 'RaiseEvent TagChanged(Tag) End Sub
and for the MultipleItemsChanged:
any help is much appreciated
