Exception: Cannot browse because the server is not compliant because it does not
13 Dec 2022 12:06 #11336 by support
If it is a screen-sharing connection, it does not help. I already explained that I need to troubleshoot the client side on my own machine.
13 Dec 2022 10:33 #11334 by micham
The connection is via Azure Portal. Inside the browser. Not a VPN.
13 Dec 2022 09:54 #11333 by support
Please answer my question. Do you mean a VPN connection? That is the only possibility.
13 Dec 2022 08:03 #11331 by micham
Hi ,
Can I send you the Word document with instructions how to connect to the customer's server to your private email?
05 Dec 2022 15:54 #11297 by support
what do you mean by "connect to the customer directly"? A VPN?
05 Dec 2022 14:45 #11295 by micham
1. It is possible to connect to the customer server directly. When can you connect? I will send you the connection instructions.
2. I tried using the EasyOPC Client ands also couldn't browse. See the attached screen capture. I also copied the exception error . See below.
Exceptions
OpcLabs.BaseLib.Runtime.InteropServices.ExtendedCOMException (0x80040112): Class is not licensed for use
+ The client method called (or event/callback invoked) was 'BrowseNodes'.
OpcLabs.EasyOpc.Implementation.ErrorEnhancement.Processed: True
OpcLabs.EasyOpc.Implementation.DAErrorEnhancement.Processed: True
ErrorCode: -2147221230
HResult: -2147221230 (0x80040112)
Message:
Source:
TargetSite:
XML Qualified Name 2: opcfoundation.org/DataAccess/:E_FAIL.0x80040112
IsEmpty: False
Namespace: opcfoundation.org/DataAccess/
Message: Problem browsing OPC Data Access (OPC-DA) branches.
Source:
TargetSite:
05 Dec 2022 10:35 #11290 by support
Thank you, but no, that's not going to work. I am talking about doing experiments with the server for many hours, and with the developer/debug version of QuickOPC which will need to be tweaked during the work. This cannot be done on your computers.
05 Dec 2022 10:26 #11289 by micham
Yes. You can get access to the server via my computer. Please schedule a meeting using the calendar link below.
calendly.com/michaelmeirovitz/30-minutes-zoom-meeting
05 Dec 2022 09:23 #11285 by support
If I get access to the server/trial (do you have download?), we can *try* to investigate and resolve it.
However, as I wrote before, I already know that the RSLinx browsing is broken, and there may be no solution, due to different approaches taken in our software.
- digitalsupport.ge.com/en_US/Article/Browsing-OPC-Items-from-RSLinx-Classic-OPC-Server
- forum.inductiveautomation.com/t/opc-browser-errors-when-brow...rslinx-classic-opc-server/1700
and maybe (although not precisely the same thing)
- www.mathworks.com/matlabcentral/answers/623558-rslinx-opc-co...ry-in-opc-data-access-explorer
- honeywellprocess-community.force.com/opcsupport/s/article/Br...from-Data-Manager-causes-hangs
05 Dec 2022 08:58 #11283 by micham
Now we can change the following settings programatically:
EnableNativeClient = True, EnableNetApiClient = False
or
EnableNativeClient = False, EnableNetApiClient = True
However, no matter which option we choose (NetApi-Client or Native-Client) when we try browsing the RSLINX OPC server for items we get an error and the items are not displayed. See the attached screen capture and the error message.
Note: In Matrikon OPC Explorer there is no problem.
Please advise.
Time to create page: 0.386 seconds
