GetConditionState exception
30 May 2023 12:24 #11774 by Quaintly3296
We talked with the opc server company and they implemented the GetConditionState function - everything works just fine now.
/close
01 Sep 2022 09:49 #11081 by support
Replied by support on topic GetConditionState exception
Thank you. If it is not confidential information, can you share which OPC server it is, ideally with its ProgID or CLSID? We have "error enhancing" feature that can hint future users as to what the possible cause of the error was.
01 Sep 2022 09:41 #11080 by Quaintly3296
Thanks for your suggestions
you were right, the server didnt implement this function.
20 Aug 2022 07:13 #11075 by support
I do not see anything apparently wrong with your code.
I suggest that you try experimenting:
1. Do you have other OPC A&E client? Can you use it to get condition states, and does it work?
2. Test the code with other OPC A&E Servers (including our test server that comes with QuickOPC). Does it work? (Some servers will not have sources at the root, so you may have to change the "" in BrowseSource to some area that does have nodes, but otherwise the approach is the same).
19 Aug 2022 14:50 #11074 by Quaintly3296
we would like to get a list of all acknowledges states ( so client is aware of conditions occured while not connected )
Our approach is to
1. browse all sources
2. query source conditions
3. get condition state
Step 1 and 2 give us the expected results
but GetConditionState always throw an exception
OpcLabs.EasyOpc.Engine.NetApiResultException (0x80070057): OPC NET API error - result ID: E_INVALIDARG; IOPCEventServer.GetConditionState + The client method called (or event/callback invoked) was 'GetConditionState'. --- End of inner exception stack trace --- at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.ErrorTransformingEasyAEClient.GetConditionState(ServerDescriptor serverDescriptor, AENodeDescriptor sourceDescriptor, String conditionName, Int64[] attributes) at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.ForwardingEasyAEClient.GetConditionState(ServerDescriptor serverDescriptor, AENodeDescriptor sourceDescriptor, String conditionName, Int64[] attributes) at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.EasyAEClientCompositor.GetConditionState(ServerDescriptor serverDescriptor, AENodeDescriptor sourceDescriptor, String conditionName, Int64[] attributes) at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.CompositeEasyAEClient.GetConditionState(ServerDescriptor serverDescriptor, AENodeDescriptor sourceDescriptor, String conditionName, Int64[] attributes) at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.ForwardingEasyAEClient.GetConditionState(ServerDescriptor serverDescriptor, AENodeDescriptor sourceDescriptor, String conditionName, Int64[] attributes) at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.DelegatingEasyAEClient.GetConditionState(ServerDescriptor serverDescriptor, AENodeDescriptor sourceDescriptor, String conditionName, Int64[] attributes) at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.ForwardingEasyAEClient.GetConditionState(ServerDescriptor serverDescriptor, AENodeDescriptor sourceDescriptor, String conditionName, Int64[] attributes) at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.DelegatingEasyAEClient.GetConditionState(ServerDescriptor serverDescriptor, AENodeDescriptor sourceDescriptor, String conditionName, Int64[] attributes) at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.ForwardingEasyAEClient.GetConditionState(ServerDescriptor serverDescriptor, AENodeDescriptor sourceDescriptor, String conditionName, Int64[] attributes) at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.DelegatingEasyAEClient.GetConditionState(ServerDescriptor serverDescriptor, AENodeDescriptor sourceDescriptor, String conditionName, Int64[] attributes) at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.LicensingEasyAEClient.GetConditionState(ServerDescriptor serverDescriptor, AENodeDescriptor sourceDescriptor, String conditionName, Int64[] attributes) at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.ForwardingEasyAEClient.GetConditionState(ServerDescriptor serverDescriptor, AENodeDescriptor sourceDescriptor, String conditionName, Int64[] attributes) at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.DelegatingEasyAEClient.GetConditionState(ServerDescriptor serverDescriptor, AENodeDescriptor sourceDescriptor, String conditionName, Int64[] attributes) at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.ErrorTransformingEasyAEClient.GetConditionState(ServerDescriptor serverDescriptor, AENodeDescriptor sourceDescriptor, String conditionName, Int64[] attributes) at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.ForwardingEasyAEClient.GetConditionState(ServerDescriptor serverDescriptor, AENodeDescriptor sourceDescriptor, String conditionName, Int64[] attributes) at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.ForwardingEasyAEClient.GetConditionState(ServerDescriptor serverDescriptor, AENodeDescriptor sourceDescriptor, String conditionName, Int64[] attributes) at OpcLabs.EasyOpc.AlarmsAndEvents.Implementation.DelegatingEasyAEClient.GetConditionState(ServerDescriptor serverDescriptor, AENodeDescriptor sourceDescriptor, String conditionName, Int64[] attributes) at OpcLabs.EasyOpc.AlarmsAndEvents.EasyAEClient.GetConditionState(ServerDescriptor serverDescriptor, AENodeDescriptor sourceDescriptor, String conditionName, Int64[] attributes) at OpcLabs.EasyOpc.AlarmsAndEvents.IEasyAEClientExtension.GetConditionState(IEasyAEClient client, ServerDescriptor serverDescriptor, AENodeDescriptor sourceDescriptor, String conditionName) at TestOPC.OPCConnector.OPCConnector.GetAcknowledgeStatus() in C:\WorkingSpace\Repositories\TestOPC\TestOPC\OPCConnector\OPCConnector.cs:line 227
Test code:
EasyAEClient _aeClient = new(); ServerDescriptor _aeServer = new( "localhost", "XXX" ); AENodeElementCollection alarmConditions = _aeClient.BrowseSources(_aeServer, ""); foreach( AENodeElement alarmCondition in alarmConditions ) { AEConditionElementCollection conditionList = _aeClient.QuerySourceConditions( _aeServer, alarmCondition.QualifiedName ); foreach (AEConditionElement conditionElement in conditionList) { try { AEConditionState condition = _aeClient.GetConditionState( _aeServer, alarmCondition.QualifiedName, conditionElement.Name ); Console.WriteLine("ConditionState:"); Console.WriteLine(" .ActiveSubcondition: {0}", condition.ActiveSubcondition); Console.WriteLine(" .Enabled: {0}", condition.Enabled); Console.WriteLine(" .Active: {0}", condition.Active); Console.WriteLine(" .Acknowledged: {0}", condition.Acknowledged); Console.WriteLine(" .Quality: {0}", condition.Quality); } catch( Exception ) { // ignored } } }
is anything wrong with our approach ?
