.NET Core Web API Application - The CertificateValidator must not be specified
21 Jul 2022 16:50 #11065 by support
Yes indeed, if the problem is not that urgent, I believe upgrading to the upcoming version is the best way to overcome the issue.
21 Jul 2022 13:36 #11064 by ZParham
I apologize for the delay.
The end user has not been able to create a stripped-down version of the project which reproduces the scenario. Because of this, they are suspecting the toolkit is not the cause in this specific case.
However, I am happy to hear that you are working on fixing a similar issue in an upcoming release, at least for my own future knowledge.
As always, thank you so much!
12 Jul 2022 09:46 #11037 by support
Hello!
is there perhaps a reproducible scenario/project?
Note: I actually have an idea of what is causing this, it is probably a bug and I was working on fixing a similar or the same thing into the upcoming version. But, with a repro, it would be easier and more reliable to provide a fix. If a repro is not feasible, I will make a an attempt to fix, but won't be able to verify it.
11 Jul 2022 13:11 #11032 by ZParham
Hello!
I have been speaking with a customer who is seeing an exception with his .NET Core Web API application using.Net 5.0 (.Net Standard). He does not see the same behavior when reading the same node from a WinForm application.
It appears that he is able to read the node value, but he receives this exception: "The CertificateValidator must not be specified in the sdkApplicationConfiguration." This is not an exception I have seen previously, nor have I been able to find much information online regarding. Is this something you have come across before?
Thank you in advance!
