OpcLabs.BaseLib.Browsing.BrowseException - exception while browsing
17 Jun 2022 14:17 #10989 by support
Ufff (sigh of relief).
Thank you for letting me know.
17 Jun 2022 13:49 #10988 by micham
You may close this case. It was a problem in my code.
17 Jun 2022 12:40 #10986 by support
In your test, is the tunneller actually connecting to a different (remote) computer, or is the DELL-I7MIKE your own (client-side, with QuickOPC) machine?
And in the customer's test?
16 Jun 2022 09:49 #10984 by micham
I am unable to upload the PNG file.
The full error is: "Timeout browsing nodes. The client method called (or event/callback invoked) was 'BrowseNodes'.
16 Jun 2022 09:48 #10983 by micham
Here is the attachment.
16 Jun 2022 09:47 #10982 by micham
My client did the same test on his computer (same configuration) and got a different error: "Timeout browsing nodes".
See the attached screen capture.
I asked him how many items are in the OPC server. Waiting for answer.
16 Jun 2022 08:58 #10981 by micham
47 items.
16 Jun 2022 08:55 #10980 by support
How many items are there in the branch you are trying to browse?
16 Jun 2022 06:11 #10978 by micham
I have QuickOPC 5.63.232, and Matrikon OPC Tunneller v.6.3.6.8582 installed on my computer. When I try browsing for items using the Tunneller:DELL-I7MIKE:Kepware.KEPServerEX.V6 server, it takes very long time and then I get this error.
Using Matrikon Explorer, browsing works fine. Can you please advise what should I do?
Exceptions
OpcLabs.BaseLib.Runtime.InteropServices.ExtendedCOMException (0xC0049001): Server failed. This error originates in the OPC Data Access server. A vendor specific fatal error has occurred within the server. The server is no longer functioning. The recovery procedure from this situation is vendor specific. The application will try to reconnect to the server after a configurable period. Technical information: The call to IOPCServer::GetStatus on the OPCServer object has returned OPC_STATUS_FAILED in the OPCSERVERSTATUS structure.
+ The client method called (or event/callback invoked) was 'BrowseNodes'.
OpcLabs.EasyOpc.Implementation.ErrorEnhancement.Processed: True
OpcLabs.EasyOpc.Implementation.DAErrorEnhancement.Processed: True
ErrorCode: -1073442815
HResult: -1073442815 (0xc0049001)
Message:
Source:
TargetSite:
XML Qualified Name 2: opcfoundation.org/DataAccess/:E_FAIL.0xC0049001
IsEmpty: False
Namespace: opcfoundation.org/DataAccess/
Message: Problem browsing OPC Data Access (OPC-DA) branches.
Source:
TargetSite:
16 Jun 2022 05:26 #10977 by support
Unfortunately I am unable to reproduce the error. I tested with QuickOPC 5.63.232, and Matrikon OPC Tunneller v.6.3.6.8582.
