- Thank you received: 4
Intrinsic Component Configuration
Basically anything that has to do with QuickOPC objects should rather be avoided.
The above was the problem for me. I was adding an event handler for the client's LogEntry event as below just before setting up the config file:
Once put the config file init code first things began behaving as expected. Thanks much for the clues.
it works for me. And, as far as I can tell, my code looks like your code. So, there must be some hidden difference.
I am attaching my full project.
Gotchas to look for:
1) Don't you have something in your code that would cause the static host be built earlier, before the code execution reaches the code you listed? Basically anything that has to do with QuickOPC objects should rather be avoided.
2) Is the .INI file actually alongside the EXE? This one got me too - I forgot to set "Copy to output directory" property on the INI file in the VS project originally.
I moved the above line to the bottom of the config init method, started a new debug session, and the EnsureDataIntegrity property still remains false as shown in the attached screenshot.
I have not checked it thoroughly, but one thing already stands out: Why do you have this line
at all, and, if you need it, why *before* configuring the "static host"?
This line causes first access to the security parameters, which will 1) initialize them to hard-coded default values, and then 2) overwrite them with the values from configurations set in the static host *at that point*. This will never be repeated then. So, the .INI file will not be considered.
Move this line after the static configuration.
And here is the initialization code to get it working:
In case it helps, here is a log entry from my application after the config file init code above completes:
When I run the final line of my init code above, the SecurityParameters.EnsureDataIntegrity property remains false (the default). I expected to see this property change to true instead. Would you mind checking to make sure I've not done something obviously wrong here? Thanks much for the guidance.
