uaHostAndEndpointDialog Error
26 Apr 2022 09:06 #10825 by support
The new version may give you licensing error, when you have your current license installed and it doe snot allow the new version.
To resolve this, you can uninstall you r license (reverting to trial mode), test with the new version, and then install your license again.
25 Apr 2022 19:18 #10821 by p-toth
Dear Moderator,
Downloaded the latest version but I have a one question.
After installing the new version of QuickOPC, UA communication will be working correctly? Because we don't have license for this version.
Best regards.
24 Apr 2022 08:54 #10819 by support
thank you for reporting the problem.
I tested with the latest released version (2022.1), and could not reproduce the issue. The reason I am doing it with 2021.1 is because even if the problem had existed in 2019.2, we would not be fixing it into that version.
If you can reproduce the problem with 2022.1, let me know, because that would mean we are doing something different.
In addition, it would be helpful to have the exception call stack.
Best regards.
22 Apr 2022 09:02 - 24 Apr 2022 08:41 #10818 by p-toth
Dear Moderator,
I want to modify some data in existing application which is break if I want to add/change new OPC UA host in uaHostAndEndpointDialog.
So when click to "Add OPC UA Host", i added OPC server IP address, press enter or click out with mouse then application is break with error "File format is not valid."(see attached picture).
I using:
Windows 10 enterprise x64 OS version: 1909
QuickOPC 2019.2
.NET 4.7.2
Source code:
private void btnBrowse_Click(object sender, EventArgs e) { uaHostAndEndpointDialog1.EndpointDescriptor = txtEndPoint.Text; if (uaHostAndEndpointDialog1.ShowDialog() == DialogResult.OK) { txtEndPoint.Text = uaHostAndEndpointDialog1.EndpointDescriptor.UrlString; } }
Could you tell me what could be the problem.
Best regards.
Last edit: 24 Apr 2022 08:41 by support. Reason: code formatting
