Authentication with X509 certificate
01 Mar 2022 16:33 #10675 by support
The file you specify needs to contain both private and public key (.PFX file, most likely).
The following user(s) said Thank You: federica
01 Mar 2022 07:05 #10669 by federica
Can you let me know where should I specify the "Private Key" parameter?
I find no way to specify this.
28 Feb 2022 17:29 #10667 by support
Assuming that you have the Isolated property on the EasyUAClient object set to 'true', then yes, this is the right place. The chosen user identity will influence all connections made by that EasyUAInstance.
There is, however, also a UserIdentity object on each UAEndpointDescriptor. It can override whatever is set in the session parameters. So, at least in scenarious, it is more logical to leave the UserIdentity in the session parameter unmodified (empty), and set the UserIdentity on the endpoint descriptor instead.
28 Feb 2022 15:32 #10662 by federica
I'm using QuickOPC COM, developing in C++.
I need to authenticate to an OPC-UA server using certificates.
In UaExpert I need to specify "Certificate" and "Private Key".
How can I specify this parameters using QuickOPC library?
I think I have found how to specify "Certificate" parameter.
_EasyUAAdaptableParametersPtr IsolatedParameters = m_clientUAPtr->GetIsolatedParameters(); _UASmartSessionParametersPtr SessionParms = IsolatedParameters->GetSessionParameters(); SessionParms->UserIdentity->X509CertificateTokenInfo->FileName = certificateParam;
Is it correct?
