[opcua] Browsing nodes
21 Feb 2022 13:48 #10643 by support
Replied by support on topic [opcua] Browsing nodes
please see the code below. I hope it helps.
// This example shows how to obtain "data nodes" under the "Objects" node, recursively. using System; using System.Diagnostics; using OpcLabs.EasyOpc.UA; using OpcLabs.EasyOpc.UA.AddressSpace; using OpcLabs.EasyOpc.UA.AddressSpace.Standard; using OpcLabs.EasyOpc.UA.OperationModel; namespace UADocExamples._EasyUAClient { partial class BrowseDataNodes { public static void Recursive() { UAEndpointDescriptor endpointDescriptor = "opc.tcp://opcua.demo-this.com:51210/UA/SampleServer"; // or "http://opcua.demo-this.com:51211/UA/SampleServer" (not in .NET Standard) // or "https://opcua.demo-this.com:51212/UA/SampleServer/" // Instantiate the client object var client = new EasyUAClient(); try { BrowseFromNode(client, endpointDescriptor, UAObjectIds.ObjectsFolder, level:0); } catch (UAException uaException) { Console.WriteLine($"*** Failure: {uaException.GetBaseException().Message}"); } } private static void BrowseFromNode( EasyUAClient client, UAEndpointDescriptor endpointDescriptor, UANodeDescriptor parentNodeDescriptor, int level) { Debug.Assert(!(client is null)); Debug.Assert(!(endpointDescriptor is null)); Debug.Assert(!(parentNodeDescriptor is null)); // Obtain all node elements under parentNodeDescriptor UANodeElementCollection nodeElementCollection = client.BrowseDataNodes(endpointDescriptor, parentNodeDescriptor); // Remark: BrowseDataNodes(...) may throw UAException; we handle it in the calling method. foreach (UANodeElement nodeElement in nodeElementCollection) { Debug.Assert(!(nodeElement is null)); Console.Write(new string(' ', level*2)); // indent Console.WriteLine(nodeElement); // Browse recursively into the node. // The UANodeElement has an implicit conversion to UANodeDescriptor. BrowseFromNode(client, endpointDescriptor, nodeElement, level + 1); // Note that the number of nodes you obtain through recursive browsing may be very large, or even infinite. // Production code should contain appropriate safeguards for these cases. } } // Example output: // //ServerStatus -> nsu=http://opcfoundation.org/UA/ ;i=2256 (Variable) // StartTime -> nsu=http://opcfoundation.org/UA/ ;i=2257 (Variable) // CurrentTime -> nsu=http://opcfoundation.org/UA/ ;i=2258 (Variable) // State -> nsu=http://opcfoundation.org/UA/ ;i=2259 (Variable) // BuildInfo -> nsu=http://opcfoundation.org/UA/ ;i=2260 (Variable) // ProductUri -> nsu=http://opcfoundation.org/UA/ ;i=2262 (Variable) // ManufacturerName -> nsu=http://opcfoundation.org/UA/ ;i=2263 (Variable) // ProductName -> nsu=http://opcfoundation.org/UA/ ;i=2261 (Variable) // SoftwareVersion -> nsu=http://opcfoundation.org/UA/ ;i=2264 (Variable) // BuildNumber -> nsu=http://opcfoundation.org/UA/ ;i=2265 (Variable) // BuildDate -> nsu=http://opcfoundation.org/UA/ ;i=2266 (Variable) // SecondsTillShutdown -> nsu=http://opcfoundation.org/UA/ ;i=2992 (Variable) // ShutdownReason -> nsu=http://opcfoundation.org/UA/ ;i=2993 (Variable) //ServerCapabilities -> nsu=http://opcfoundation.org/UA/ ;i=2268 (Object) // OperationLimits -> nsu=http://opcfoundation.org/UA/ ;i=11704 (Object) // MaxNodesPerRead -> nsu=http://opcfoundation.org/UA/ ;i=11705 (Variable) // MaxNodesPerHistoryReadData -> nsu=http://opcfoundation.org/UA/ ;i=12165 (Variable) // MaxNodesPerHistoryReadEvents -> nsu=http://opcfoundation.org/UA/ ;i=12166 (Variable) // MaxNodesPerWrite -> nsu=http://opcfoundation.org/UA/ ;i=11707 (Variable) // MaxNodesPerHistoryUpdateData -> nsu=http://opcfoundation.org/UA/ ;i=12167 (Variable) //... } }
The following user(s) said Thank You: yong
21 Feb 2022 07:30 #10641 by yong
Replied by yong on topic [opcua] Browsing nodes
Yes, I would appreciate it if you could provide actual example code.
21 Feb 2022 06:39 #10640 by support
It is not clear what you are asking for. Do you want tor recursively browse into the nodes, and basically obtain the whole tree?
If so, it looks like that you already have an example code that gets you the first level. Each of the result "elements" contains a node Id of the node you obtained. You can use that to browse further from that node, passing it as starting element (an additional argument) to one of the BrowseXXXX methods (possible the BrowseDataNodes again).
With this, do you need an actual example code for that ?
21 Feb 2022 06:26 #10639 by yong
[opcua] Browsing nodes was created by yong
I am using opclabs quick opcua version 5.23 for C# .NET core.
I need to find a way to programmatically browse like a program uaexpert node.
I couldn’t find any documentation for that, do you have any example code for that?
How do you browse beneath (forward) one of the nodes? For instance the node with display name “Data”?
