Update Strategy
10 Feb 2022 18:05 - 10 Feb 2022 18:06 #10609 by support
Replied by support on topic Update Strategy
We only provide bugfixes or security fixes to the current version - if such fix is necessary, it is labeled as a new build of the same version.
There is never an API change inside the same version.
New versions (with feature upgrades) are generally backward compatible. We keep breaking changes to minimum, but cannot completely avoid them (but if they happen, they are usually in less-used parts, and the changes needed are trivial). All such changes are documented in the "What's New" document that comes with a new version - you can access those from kb.opclabs.com/Versions .
Last edit: 10 Feb 2022 18:06 by support.
09 Feb 2022 22:06 #10601 by BurkhardSchaefer
How long (how many month/years) do you offer security fixes for your versions (i. e. without upgrades to a new version)?
Do you ensure the backward compatibility of bugfixes, security fixes or even feature-upgrades (i. e. do we need to adapt our code to modified interfaces)?
