what is the default value of the sampling interval of OPC UA client?
20 Oct 2021 16:24 #10270 by support
Many overloads of the SubscribeXXXX methods have an argument for the sampling interval, so they actually force you to pass in a concrete value.
If you are, however, using an overload that - directly or indirectly - uses the UAMonitoringParameters object, then indeed you might not necessarily have to set the sampling interval (in the SamplingInterval property) explicitly, although that would be unusual.
You would find that if you read the initial value of the UAMonitoringParameters.SamplingInterval, it defaults to 1000 milliseconds (1 second).
20 Oct 2021 12:42 #10269 by Jennee
We are using the OPC UI Client SDK and don't set the sampling interval proactiv. What is then the default value of the sampling interval?
