Error: Access is denied. + The client methods called (or event/callback invoked)
31 May 2021 08:25 #9709 by micham
I have placed the file "appsettings.json" in the BIN folder of our software. See the attached screen capture.
I have restarted our software, but the same error is received. See the exception below.
Exceptions
System.UnauthorizedAccessException: Access is denied.
+ The client method called (or event/callback invoked) was 'BrowseNodes'.
OpcLabs.EasyOpc.Implementation.ErrorEnhancement.Processed: True
OpcLabs.EasyOpc.Implementation.DAErrorEnhancement.Processed: True
HResult: -2147024891 (0x80070005)
Message:
Access is denied.
Source: OpcLabs.EasyOpcRaw.DataAccess.RawEasyDAClient
TargetSite:
Message: Problem browsing OPC Data Access (OPC-DA) branches.
Source:
TargetSite:
Any idea what to do?
25 May 2021 11:54 #9701 by support
this is difficult to answer. As I wrote, it is a new implementation of parts of EasyOPC "Classic" internal code. We have tested it well, and selected customers are already using - plus, *any* customer that is using .NET Core or .NET 5 (as opposed to .NET Framework) is using it, because it is the one available there.
But, we have not yet made it the default implementation for .NET Framework, because there is a small risk that somebody's app will broke (although it could be switched back using a config file too). We will eventually make the switch, but the date is not yet set.
Unless you afraid to, you can make it your default (by using the config file), and report any issues to me. In the worst case, you can always switch back by deleting the file.
25 May 2021 06:04 #9699 by micham
Thank you for your answer. Can I place this file in the EXE folder in any case? Or, just if I have a browsing problem?
23 May 2021 13:45 #9695 by support
Programs based on QuickOPC sometimes require different DCOM settings different from other client programs, due to internal implementation differences.
If DCOM cannot be configured to resolve the issue, try this: Extract the appsettings.json file from the attached ZIP file, and place the file alongside the application (i.e. into the same directory where the EXE runs). This instructs QuickOPC to use a different implementation, closer to the "normal".
It is best to use the file from the attachment, but for clarity, here is its contents:
{ "OpcLabs.EasyOpc.DataAccess.EasyDAClient": { "InstanceParameters": { "EnableNativeClient": false, "EnableNetApiClient": true } } }
File Name: appsettings.zip
File Size:0 KB
    22 May 2021 14:58 - 23 May 2021 06:53 #9693 by micham
    I have a customer who is getting an error when trying to connect with a remote OPC DA server (Unicorn DA Server).
    Other browsers like Matrikon OPC Explorer works well. See the attached screen captures.
    Exceptions
    Type: System.UnauthorizedAccessException
    Message:
    Access is denied.
    TargetSite:
    Source:
    TargetSite:
    We are using Quick OPC 2021.1 (5.60.107.1)
    Any idea how to fix?
  • Last edit: 23 May 2021 06:53 by micham.
