Does the UAGenericObject work with the CallMethod?
30 Mar 2021 19:27 - 30 Mar 2021 19:30 #9581 by support
Great! Thanks for letting me know so soon.
The build I have provided is ready to be rolled out. There was just this single targeted change in it.
I am not sure if I can describe the bug briefly. Basically, in order to convert the UAExtensionObject to UAGenericObject, one needs an indication of which server (endpoint) it came from, because the encoding Id contained in the extension object is generally only valid for certain server, and it is this server that needs to be interrogated for everything that has to do with how the data is encoded. The code that converted the inputs and output of the UA Read-s, and Write-s was correct, but in the code that was handling the UA Call-s, the information about the endpoint was lost - an empty endpoint was passed to the parts that do the encoding/decoding.
Last edit: 30 Mar 2021 19:30 by support.
30 Mar 2021 19:21 #9580 by Restrepo
It works!!! it looks like whatever change you made got rid of the "Host cannot be empty" error the customer was getting. Out of curiosity, would you mind sharing the issue that was generating that error?
We would appreciate it if you could please let us know when you are rolling this build-out so that we can do the same. Unless the build you provided me with is ready to be made public, in which case I would appreciate it if you could let me know if is ok with making this latest build public as well.
Many thanks for the assistance with this one.
28 Mar 2021 16:08 #9577 by support
unfortunately I do not have any server capable of returning complex data from method calls (this was also the reason this feature was overlooked at first; but I have now re-checked the server available to me, to no avail).
In the week starting April 12, 2021, there will be a virtual OPC Interoperability Workshop. I will specifically ask around all participant and check whether they have this or can expose it.
I have further analyzed the code. And I think I have found what might be causing the "Host cannot be empty" error in this case. And I have made a "fix" - without being able to test it out, of course.
Please have the customer download and use build 136.1 or later of version 2021.1. It is available here:
www.opclabs.com/files/downloads/OpcDataClient/2021.1/OPC%20D...Client-2021.1-Windows-Full.exe .
Hopefully this will work, or if not, at least the customer will understand that such repeated attempts are our best option in this situation.
26 Mar 2021 03:21 #9563 by Restrepo
So unfortunately it looks like the OPC UA server is hosted on an HMI that is part of Filler equipment from a vendor named Kronos so he does not have direct access to the OPC UA server, unfortunately.
Now, do you happened to know of an OPC UA server that supports Method Calls capable of returning Complex Data? I was running my test incorrectly against OPC Router until I realized that OPC Router does not support Methods returning objects so I am not able to test if this an issue with his OPC UA server only or if this is happening with any OPC UA server that supports Methods returning Complex data.
If you have a test server in mind, we could try to test something simple where the server returns an object whenever the UA method is called. If this works, we should be able to ask the customer to try it on his end so that we can determine if this isolated to his Server only.
25 Mar 2021 12:59 #9557 by support
thanks for update.
It is not necessary to try to find anything wrong with the "host" on the user side. It is correct there. The problem will most likely be inside QuickOPC when it later tries to access the same server for the purpose of obtaining metadata needed to decode the custom data types.
If the endpoint cannot be made public: Which OPC server is it then? Can we get hold of it and configure it in a similar way?
25 Mar 2021 12:18 #9555 by Restrepo
I had the chance to talk to the customer and it looks like it will not be possible to expose the endpoint. The server is on a network that has no internet connection.
He also was able to do more testing and he found out that if he calls a method that only returns a single integer value, it works great. He gets back the integer with no errors.
he only gets the error I sent you before ("Host cannot be empty") when he calls a method that returns complex data.
he also implemented the DiscoverLocalEndpoints call in his test app to make sure he used an Endpoint that was sent from the Server itself, see below code. In this case, the Endpoint must be valid.
OpcLabs.EasyOpc.UA.Discovery.UADiscoveryElementCollection lEndpoints =
mClient.DiscoverLocalEndpoints("opc.tcp://10.97.219.220:4840/");
UAEndpointDescriptor endpointDescriptor = lEndpoints[0];
object[] lOutput = mClient.CallMethod(endpointDescriptor, "ns=2;s=MethodSet",
"ns=9;s=DMM.Messages.GetActiveMessages");
The error message indicates the Hostname must not be empty. Since he is getting the Endpoint from the host itself, the hostname is correct and not empty. Please see attached screen print of the EndPoint Descriptor.
So, it looks like the client can get to the server and call the methods just fine. It fails when the method returns complex data.
Also, I have used a generic client to do the method call and it returned and displayed the data correctly, so it is not an issue with the OPC Server side.
Do you have any other ideas on how to troubleshoot this behavior? Thank you for your support.
    20 Mar 2021 09:16 #9519 by support
    I agree there is nothing wrong with the endpoint (host name).
    Is there any chance the customer can expose the endpoint on the Web (to a specified IP that I would give them) so that I can debug it ftom my side?
    19 Mar 2021 13:36 #9517 by Restrepo
    I just want to follow up with this. I was able to get the customer to upgrade to the latest version 5.60 but now the same code is yielding this error:
    OpcLabs.EasyOpc.UA.OperationModel.UAException: An OPC-UA operation failure with error ID 'OpcLabs.UAEngine=1202' occurred, originating from '' and with depth of 1. The inner exception, of type "OpcLabs.EasyOpc.UA.Engine.UAEngineException", contains details about the problem. ---> OpcLabs.EasyOpc.UA.Engine.UAEngineException: Invalid opc.tcp discovery URL ("opc.tcp:"): The Host must not be empty.
    + The client method called (or event/callback invoked) was 'CallMultipleMethods'.
    at OpcLabs.EasyOpc.UA.OperationModel.UAException.CheckSuccess(Exception exception)
    at OpcLabs.EasyOpc.UA.OperationModel.UAException.CheckSuccess(OperationResult operationResult)
    at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.CallMethod(IEasyUAClient client, UACallArguments callArguments)
    at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.CallMethod(IEasyUAClient client, UAEndpointDescriptor endpointDescriptor, UANodeDescriptor objectNodeDescriptor, UANodeDescriptor methodNodeDescriptor)
    at TestOPCUAClient.Form1.btnGetAlarms_Click(Object sender, EventArgs e) in c:\TFS-TPW\KA - IMS Krones Alarmer\Main\TestOpcUAClientNewSDK\Form1.cs:line 62
    Now, looking at the error description, it looks like the host is empty but it does not make any sense because the host is never empty as you will see in the code. Attached is the code that the customer is running. Please do let time know if you have any suggestions or questions.
    15 Mar 2021 11:43 #9491 by support
    thank you for the details.
    I have determined that the problem is related the fact that the value returned in the method 'out' argument is an *array* of object of custom data type. By inspecting the code, I have found that returning (converting) such arrays is properly supported for Reads, but - by omission - not in the 'out' arguments of UA method calls.
    Version 5.54 is no longer maintained.
    As I was in process of releasing version 5.60 (2021.1), I have made a fix for this issue into this new version. It was released today.
    In theory the same fix could be made as the "very last fix" into version 5.59 (2020.3), but I do not think it is necessary.
    12 Mar 2021 13:05 #9490 by Restrepo
    Thank you for the reply. I had the customer tried with version 5.59 and he still gets the same issue where he gets back an array of objects and he is unable to cast to the UAGenericObject.
    The Type of the object that is in the first index value of the Output is an array of Objects. The objects in this array are of type "UAExtensionObject", which only has binary data. (See screenshot)
    He still is not able to cast any level of the returned objects to the UAGenericObject class, so he cannot see any of the returned complex data.
    Do you have any other suggestions?
