Unable to use Username/Password identity with SecurityPolicy 'None'
16 Feb 2021 10:03 #9451 by support
this appears to be a bug in QuickOPC. I was able to reproduce it. Thank you for reporting. It will be fixed in the upcoming version (2021.1). For now, there is a workaround:
a) If you are using the EasyUAClient with default Isolated property setting (false):
EasyUAClient.AdaptableParameters.SessionParameters.AlwaysPreselectEndpoint = true;
b) if you have set EasyUAClient's Isolated property to 'true':
client.IsolatedParameters.SessionParameters.AlwaysPreselectEndpoint = true;
I hope this helps
15 Feb 2021 15:45 #9448 by Mykola
We have issue using a server endpoint with SecurityMode 'None' and SecurityPolicy "None" that requires client to provide username/password identity.
An internal "System.NullReferenceException" is thrown by QuickOPC.
We don't have that issue with endpoints that use different security policy or anonymous identity.
Server configuration:
<ServerSecurityPolicy> <SecurityMode>None_1</SecurityMode> <SecurityPolicyUri>http://opcfoundation.org/UA/SecurityPolicy#None</SecurityPolicyUri> </ServerSecurityPolicy> </SecurityPolicies> <UserTokenPolicies> <ua:UserTokenPolicy> <ua:TokenType>UserName_1</ua:TokenType> </ua:UserTokenPolicy> </UserTokenPolicies>
Our code (simplified):
var opcClient = new EasyUAClient() { Isolated = true }; var sessionParameters = opcClient.IsolatedParameters.SessionParameters; sessionParameters.EndpointSelectionPolicy.AllowedMessageSecurityModes = OpcLabs.EasyOpc.UA.Engine.UAMessageSecurityModes.SecurityNone; sessionParameters.EndpointSelectionPolicy.SecurityPolicyUri = new Uri("http://opcfoundation.org/UA/SecurityPolicy#None"); sessionParameters.UserIdentity.UserNameTokenInfo = new UserNameTokenInfo(_clientConfiguration.Username, _clientConfiguration.Password); var endpointDescriptor = new UAEndpointDescriptor(_clientConfiguration.EndpointUrl); var res = opcClient.BrowseDataNodes(endpointDescriptor);
Client log:
2021-02-15 17:32:05.970 [VRB] EasyUAClient Information OPCLabs-UAEngine: The OPC-UA engine will resolve the client instance certificate parameters directory store path to "C:\ProgramData\OPC Foundation\CertificateStores\MachineDefault". 2021-02-15 17:32:06.010 [VRB] EasyUAClient Information OPCLabs-UAEngine: The OPC-UA engine has determined the application configuration parameters as listed below. ProductUri: urn:literal:string:GenericTestTool 2021-02-15 17:32:06.078 [VRB] EasyUAClient Information OPCLabs-EasyUAClient: Licensing for EasyUAClient component started, license serial number *******, issuer name "OPC Labs", subject name "***************". 2021-02-15 17:32:06.268 [VRB] EasyUAClient Information OPCLabs-UAEngine: External information from "InteractionProviderCompositor" (0,1): Newly selected interaction handler is 'Console'. 2021-02-15 17:32:06.329 [VRB] EasyUAClient Information OPCLabs-UAEngine: The OPC-UA engine has successfully connected to the underlying subsystems. 2021-02-15 17:32:06.444 [VRB] EasyUAClient Information OPCLabs-UAEngine: The OPC-UA client session with connect sequence number 1 is connecting to endpoint URL "opc.tcp://localhost:9090/GenericSimulator". 2021-02-15 17:32:06.468 [VRB] EasyUAClient Information OPCLabs-UAEngine: The OPC-UA client session with connect sequence number 1 has synthesized an OPC-UA endpoint (without preselection) with following parameters: Endpoint URL "opc.tcp://localhost:9090/GenericSimulator", message security mode 'None', security policy URI "http://opcfoundation.org/UA/SecurityPolicy#None", transport profile URI ", server certificate presented: no, use binary encoding: yes. 2021-02-15 17:32:06.733 [VRB] EasyUAClient Information OPCLabs-UAEngine: OPC-UA endpoint selection on discovery URL "opc.tcp://localhost:9090/GenericSimulator" candidate report (1 entries) follows. [0:Winner(1000+0)]. 2021-02-15 17:32:06.743 [VRB] EasyUAClient Information OPCLabs-UAEngine: The OPC-UA client session with connect sequence number 1 user token selection on endpoint URL "opc.tcp://localhost:9090/GenericSimulator" candidate report (1 entries) follows. [0:Winner("http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0")]. 2021-02-15 17:32:06.745 [VRB] EasyUAClient Information OPCLabs-UAEngine: The OPC-UA client session with connect sequence number 1 on endpoint URL "opc.tcp://localhost:9090/GenericSimulator" has been associated with user identity token type 'UserName', display name "qqqq". 2021-02-15 17:32:06.773 [VRB] EasyUAClient Error OPCLabs-UAEngine: INTERNAL ERROR. The OPC-UA engine might be in an unstable state. An exception of type "System.NullReferenceException" from source "Opc.Ua.Core" has occurred in OPC-UA SDK action 'static Session.Create'. The exception descend follows. (1) {System.NullReferenceException} Opc.Ua.Core(GetPlainTextBlockSize) -> Object reference not set to an instance of an object. 2021-02-15 17:32:06.781 [VRB] EasyUAClient Warning OPCLabs-UAEngine: The OPC-UA client session with connect sequence number 1 failed to connect to endpoint URL "opc.tcp://localhost:9090/GenericSimulator". INTERNAL ERROR. An exception of type "System.NullReferenceException" from source "Opc.Ua.Core" has occurred in OPC-UA SDK action 'static Session.Create'. The exception descend follows. (1) {System.NullReferenceException} Opc.Ua.Core(GetPlainTextBlockSize) -> Object reference not set to an instance of an object. + Following (15) events were gathered during the action on activity ID [3], in the order of first occurrence: SDK trace: CreateSession Called. RequestHandle=1, PendingRequestCount=1 [4] SDK trace: Token #0 created. CreatedAt = 15:32:06.611 . Lifetime = 3600000 [4] SDK trace: Token #1 activated. CreatedAt = 15:32:06.611 . Lifetime = 3600000 SDK trace: CreateSession Completed. RequestHandle=1, PendingRequestCount=0 SDK trace: Revised session timeout value: 600000. SDK trace: Max response message size value: 4194304. Max request message size: 4194304 SDK trace: Server signature is null or empty. SDK trace: CloseSession Called. RequestHandle=2, PendingRequestCount=1 SDK trace: CloseSession Completed. RequestHandle=2, PendingRequestCount=0 [7] SDK trace: TCPCLIENTCHANNEL SOCKET CLOSED: 00000B0C, ChannelId=1 Exception: {Opc.Ua.ServiceResultException} BadSecureChannelClosed SDK trace: CloseSession Called. RequestHandle=3, PendingRequestCount=1 2*Exception: {System.ObjectDisposedException} Cannot access a disposed object. SDK trace: CloseSession Completed. RequestHandle=3, PendingRequestCount=0, StatusCode=Bad + Events starting with activity ID in [] may not necessarily be related to the current action. 2021-02-15 17:32:06.783 [VRB] EasyUAClient Information OPCLabs-UAEngine: The OPC-UA client session on endpoint URL "opc.tcp://localhost:9090/GenericSimulator" failed at tick 6651770453 and will retry in 10000 milliseconds. 2021-02-15 17:32:06.791 [VRB] EasyUAClient Warning OPCLabs-UAEngine: The status subscription for an OPC-UA session on endpoint URL "opc.tcp://localhost:9090/GenericSimulator" is in failure. Further such warnings on this session will not be logged. INTERNAL ERROR. An exception of type "System.NullReferenceException" from source "Opc.Ua.Core" has occurred in OPC-UA SDK action 'static Session.Create'. The exception descend follows. (1) {System.NullReferenceException} Opc.Ua.Core(GetPlainTextBlockSize) -> Object reference not set to an instance of an object. + Following (15) events were gathered during the action on activity ID [3], in the order of first occurrence: SDK trace: CreateSession Called. RequestHandle=1, PendingRequestCount=1 [4] SDK trace: Token #0 created. CreatedAt = 15:32:06.611 . Lifetime = 3600000 [4] SDK trace: Token #1 activated. CreatedAt = 15:32:06.611 . Lifetime = 3600000 SDK trace: CreateSession Completed. RequestHandle=1, PendingRequestCount=0 SDK trace: Revised session timeout value: 600000. SDK trace: Max response message size value: 4194304. Max request message size: 4194304 SDK trace: Server signature is null or empty. SDK trace: CloseSession Called. RequestHandle=2, PendingRequestCount=1 SDK trace: CloseSession Completed. RequestHandle=2, PendingRequestCount=0 [7] SDK trace: TCPCLIENTCHANNEL SOCKET CLOSED: 00000B0C, ChannelId=1 Exception: {Opc.Ua.ServiceResultException} BadSecureChannelClosed SDK trace: CloseSession Called. RequestHandle=3, PendingRequestCount=1 2*Exception: {System.ObjectDisposedException} Cannot access a disposed object. SDK trace: CloseSession Completed. RequestHandle=3, PendingRequestCount=0, StatusCode=Bad + Events starting with activity ID in [] may not necessarily be related to the current action. 2021-02-15 17:32:09.835 [ERR] An error occured while initializing client OpcLabs.EasyOpc.UA.OperationModel.UAException: An OPC-UA operation failure with error ID 'OpcLabs.BaseLib.Portable.CustomException' occurred, originating from 'Opc.Ua.Core' and with depth of 2. The inner exception, of type "OpcLabs.BaseLib.Portable.CustomException", contains details about the problem. ---> OpcLabs.BaseLib.Portable.CustomException: INTERNAL ERROR. An exception of type "System.NullReferenceException" from source "Opc.Ua.Core" has occurred in OPC-UA SDK action 'static Session.Create'. The exception descend follows. (1) {System.NullReferenceException} Opc.Ua.Core(GetPlainTextBlockSize) -> Object reference not set to an instance of an object.
