How to use PercentDeadband
18 Jul 2021 18:35 #10011 by support
Replied by support on topic How to use PercentDeadband
Thanks for update.
Consider reporting it to the server vendor then...
The following user(s) said Thank You: goosvanbeek
18 Jul 2021 17:49 #10010 by goosvanbeek
My bad luck, I think.
I tried it with the original OpcFoundation dll's. Worked fine with the OPCLabs.KitServer.2, but not with the Freelance2000OPCServer.110.1 server.
Thanks for the suggestion.
Goos van Beek.
18 Jul 2021 12:12 #10009 by support
This can be a problem on the server side. Have you tried with some other OPC client? If not, please do so.
If you get the same problem with some other OPC client, then it is most likely a problem on the server side and we would not be able to do anything about it. The workaround is add filtering code on the client side, but that of course does not reduce the amount of communication between the OPC client and the server, which is one of the reasons the PercentDeadband exists.
If it works with some other client, please post here the details of that test, and we will work on it further.
18 Jul 2021 11:02 #10008 by goosvanbeek
At the moment PercentDeadband is working fine with the OPCLabs.KitServer.2. But it won't work with a Freelance2000OPCServer.
Do you have any suggestions for what I can do about it?
Windows Server 2019
OpcLabs 5.61.241 (Nuget)
public static void TestPercentDeadbandAbb(){ using(var client = new EasyDAClient()){ client.ItemChanged += client_ItemChanged_PercentDeadband; Console.WriteLine("Subscribing with 10% deadband..."); var handle = client.SubscribeItem("", "Freelance2000OPCServer.110.1", "62_TICA227_PV", VarTypes.Empty, 100, 10.0f, null); Console.WriteLine("Waiting for 30 seconds..."); Thread.Sleep(30 * 1000); Console.WriteLine("Changing subscription to 0% deadband..."); client.ChangeItemSubscription(handle, new DAGroupParameters(100, 0.0f)); Console.WriteLine("Waiting for 30 seconds..."); Thread.Sleep(30 * 1000); Console.WriteLine("Unsubscribing..."); client.UnsubscribeAllItems(); Console.WriteLine("Waiting for 10 seconds..."); Thread.Sleep(10 * 1000); } } // Item changed event handler static void client_ItemChanged_PercentDeadband(object sender, EasyDAItemChangedEventArgs e){ count++; if(e.Succeeded) Console.WriteLine(e.Vtq); else Console.WriteLine("*** Failure: {0}", e.ErrorMessageBrief); }
08 Feb 2021 16:41 #9409 by goosvanbeek
Hi support,
It's not that urgent, I'll wait for the upcoming version.
Thanksfor your reply.
Goos van Beek.
08 Feb 2021 13:55 #9407 by support
yes, you are right - there is a bug in QuickOPC in this version.
How urgent is it for you to get it fixed? (unless it is urgent, it will get fixed into the upcoming version, 2021.1).
08 Feb 2021 12:36 #9406 by goosvanbeek
Hello support,
I'm trying to implement PercentDeadband as described in this example , but it doesn't seem to work. I don't see any difference in deadband between the percentages, even if I change it to 90%. I expected a less frequent update, based on the difference in value.
I also tested it on a ABB Freelance server, but with the same result.
Can you help me any further?
Goos van Beek.
Windows server 2019
.Net Framework 4.72
QuickOPC 5.59.1055
