ReadMultipleItemValues Function Error
07 Dec 2020 19:18 #9233 by support
You are passing an array of DAItemValueArguments to ReadMultipleItemValues, which expect an array of DAReadItemArguments.
Since DAItemValueArguments is a structure that is used when writing the values (and not reading them), the code makes no sense. If it had compiled before, which could have been due to some implicit conversion, it was not correct.
Use DAReadItemArguments instead.
The following user(s) said Thank You: PythonByte
07 Dec 2020 14:56 #9230 by PythonByte
Guys,
I have a working function in version 5.23 and I upgraded to the latest version 5.59 and it doesn't work anymore. It seems the parameter type have changed or something for the ReadMultipleItemValues function. Here is my working solution in 5.23:
Public Function SyncReadItems(ByRef Tags As SQTags) As Boolean Dim argumentArray As DAItemValueArguments() = New DAItemValueArguments(Tags.Count - 1) {} Dim handleResult() As ValueResult For i As Integer = 0 To Tags.Count - 1 argumentArray(i) = New DAItemValueArguments(m_MachineName, m_OPCServerName, Tags.Item(i).ClientTagname, Tags.Item(i).Value) Next i handleResult = m_opcClient.ReadMultipleItemValues(argumentArray) For i As Integer = 0 To Tags.Count - 1 If Not handleResult(i).Succeeded Then Return False End If Next i Return True End Function
m_opcClient.ReadMultipleItemValues(argumentArray) line is complaining about the argumentArray. It says:
'DAItemValueArguments()' cannot be converted to 'DAReadItemArguments()' because 'DAItemValueArguments' is not derived from 'DAReadItemArguments'
