OPC-UA operation failure with error ID 'UAEngine=2307' occurred
24 Oct 2020 08:42 #9023 by support
is the the only kind of exception, or do you also get some different exception, possibly before or after that (when calling operations on the same OPC server?).
If you also get different exception(s), please provide information about them.
If there are no other exception or problem symptoms, we will need to obtain more from inside the component. Please follow the instructions here: kb.opclabs.com/QuickOPC:_How_to_enable_extended_tracing , enabling the common parts as in the example given.
23 Oct 2020 10:08 #9022 by k_ito@sehouse.co.jp
2020/10/23 13:41:39,read_opc-1 An OPC-UA operation failure with error ID 'UAEngine=2307' occurred,
 originating from '' and with depth of 1.
 The inner exception, of type "OpcLabs.EasyOpc.UA.Engine.UAEngineException",
 contains details about the problem.
 場所 OpcLabs.EasyOpc.UA.IEasyUAClientExtension.Read(IEasyUAClient client, UAReadArguments readArguments)
場所 OpcLabs.EasyOpc.UA.IEasyUAClientExtension.Read(IEasyUAClient client, UAEndpointDescriptor endpointDescriptor, UANodeDescriptor nodeDescriptor, UAAttributeId attributeId)
場所 opc_ua.form_main.read_opc(UAAttributeData attributeData, EasyUAClient easyUAClient1)
 場所 D:\\work\opc_ua\formMain.vb:行 120
No information found
.What should i do.
