APCViolation Live Mapping
20 Oct 2020 07:24 #9013 by support
Replied by support on topic APCViolation Live Mapping
as far as I can tell this is a false flagging.
Live Mapping does not do anything special - it is just a layer over the "normal" API (EasyDAClient or EasyUAClient) - essentially, in the end, doing the same things as you would do if you have programmed the operations manually in your own code.
Recommendation: Report it to Sophos as false positive, and ask for description of any actual malicious behavior they can show.
20 Oct 2020 06:54 #9012 by petegoodman
Whilst evaluating fitness for use, I am noticing a problem with Live Mapping whilst communicating with other equipment on our network.
Sophos is flagging the communication as a 'APCViolation' malicious behavior prevented in TCP/IP Services Application. There is no problem doing simple read/write operations with imperative programming, only when using the live mapping.
Do you have any advice/tips to solve this issue?
Time to create page: 0.161 seconds
